A/C won't blow through vents
I have a 2005 Expedition. The A/C won't blow through the vents consistantly. It does it intermittently. It will come out of the defroster and floor, but when I place it on vents it works for a while and then stops blowing air through the vents
any suggestions on how to fix or where I can look up a fix for DIY fix
Unemployed and need to watch spending right now
Just an FYI. IINM, when you place the control in the 'Vents' position, the A/C is shut down and you should only get outside air through the 'vents'. (I think what you are describing is that you don't get ANY air through the vents, no A/C air and no outside air)
Bigbruce
10-24-2015 05:20 PM
Thomas White
07-11-2015 01:25 PM
