newrider3's F-100
problems with this search engine is that it doesn't know that "gage" and
gauge" should be the same thing, and lots of people misspell things out here.
miss something somewhere?
newrider: 1980 is a one-year wonder, the dash wiring is different in it than the
other 80s variants, you don't want a 1980 circuit film unless you want your
high-beam indicator lamp to blink at ya when you try to use your left turn
signal (or something equally wrong, 81-F-150-Explorer knows for certain).
About your gauges, you'll need different sending units on the engine for the
ones that are presently idiot lights. The ammeter is a whole different subject
entirely, requiring an ammeter shunt in your wiring to avoid melting the
insulation and possible fires. Best to get yourself a factory wiring diagram.
The tach will be pretty easy but it depends... are you gonna be using a
Ford-supplied cluster circuit film or no? If so, everything should be plug-n-play;
if not, there are different wiring requirements depending on 6- or 8-cyl engine.
Try to find more in the archives....
From what I've found, I can take the new cluster, and install the original idiot lights and circuit paper on it, and use this method to hard wire in the tach. The rest would then just plug in.
Does this sound right?
connector for the "new" cluster (the one with gauges + tach) is physically
bigger (it has more wires and more leads) than your existing connector + the
rectangular holes in the backs of the clusters for those connectors are in
different locations, making for entirely different circuit films. I don't know how
you'd handle the relocation of that connector, the shunt thing on the back of
your existing connector, etc. etc. etc.
If you want to do this, my best advice to you is to get yourself an original Ford
factory wiring diagram, it will help explain a LOT of things. Lots of places sell
'em (including eBay) here's a place I bought some other manuals from and they
provided good service to me, it looks like you can buy a reprint for $25.
http://www.lloydsautolit.com/index.html
Other places in the archives, search on "shop manuals" (with the quotes).
-chris
Hope this helps anyone else out that has this problem.
I came across a deal on a mostly parted '89 F250, but with a good cab. It had a 460 and automatic trans. My truck has the 300-6 and a 4 speed. If I pick it up, where am I going to have compatibility issues with swapping the cab over? What will I have to do about the dash, clutch linkage, steering linkage etc?
Finally got it registered and to my house; worked on it a bit since school was out for Labor Day. Took out the seat and most of the trim panels, found a ****load more mouse nests. One was inside the door?!??
Pulled up the nasty floormat, and lo and behold, found some rot on the passenger side. Scraped off a bunch of rust, replaced the metal, and threw down some rust converter. Need to get a can of bedliner one of these days and do the whole interior of the cab.
That's always good...
Found this jammed inside the driver's door, apparently there wasn't a fitting replacement speaker to be found
#30
