Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Georgia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
  #1 (permalink)
Old 08-08-2009, 03:57 PM
stemwill stemwill is offline
Garage is empty, add now
stemwill is starting off with a positive reputation.
ABS light on 2000 F-350 DRW 4WD 7.3 diesel
ABS light came on . After several off and on movements with switch light went out for about 100 miles. Came back on and then went out on its on for 20 miles then came back on. Checked fuses for ABS. Had truck scanned. Scan says all three sensors are bad. Don't think all three would go bad at once. Cleared codes and left shop. Light immediately came back on. Checked continuity from sensor to module (disconnected plugs on fenderwell and rear axle prior to continuity check). All six wires are good. Next Step?
Tags
1997, 2000, 2001, 350, 73, 99, abs, code, diesel, f350, ford, front, light, parts, sensor, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
