Expedition rear axle problems - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 08-08-2009, 02:34 PM
NorthCarolinaExpy's Avatar
NorthCarolinaExpy NorthCarolinaExpy is offline
NorthCarolinaExpy is starting off with a positive reputation.
I had the following work done on my 2001 Expedition 5.4L January 2007:
Front Brake pads, Front brake rotors, Wheel bearings repacked, replace front grease seals
Rear Brake pads, Rear rotors turned
Rear Axle Seals replaced both sides
170,200
Now (230,000 miles) I'm getting a slight grinding noise from the rear end. Ford Dealership has told me I need a rear axle rebuild ($1900). I've never had a vehicle with this many miles on it that needed this kind of extensive work. What about simply replacing the differential fluid?? I dont believe the Dealership took the "pumpkin" off to examine the gears for shavings and there does not appear to be any leakage under the rear axle onto pavement.
The grinding noise is very obvious at low speeds, but not at higher speeds (over 30mph).
thanks for the help, guys!
Old 08-08-2009, 10:47 PM
wojolsc wojolsc is offline
wojolsc is starting off with a positive reputation.
Don't worry about it
At 230,000 I wouldn't worry too much especially if it is slight. Go ahead and change the fluid and drive it until it gets worse. It could make that noise for another 230,000 before it fails. The repairs will cost the same no matter what.
Wojo
Old 08-11-2009, 09:50 PM
Second opinion today
I took my 2001 Expy to another mechanic and they have diagnosed the problem as a flat spot on the bearing inside the differential. A rebuild job was estimated to be $1400.
Thanks for the above advice as I will be driving it a bit longer. The noise is not yet bothersome.
Old 08-11-2009, 10:58 PM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Better bring it to a 3rd mechanic because this one got it wrong too. Flat spots on bearing cause clicking not grinding sounds.
It's been 60,000 miles since you had the brakes done. I would be more inclined to think the rear grinding noise is a brake problem and not a differential one.
Have to tried to use your parking brake lately?
Old 08-14-2009, 02:06 PM
Rear noise
Thanks on the 3rd opinion. It's been a guessing game with the mechanics involved. . (Ford Dealership and Tire and Wheel repair shop). I do use the parking brake 80% of the time and it's working good. The Tire and Wheel shop took all the tires off and inspected the rotors (I watched), but it could still be a brake issue since they didnt disassemble anything, only visual inspection.
Old 08-14-2009, 02:34 PM
The reason I asked about the parking brake is because it is hidden. You cannot inspect it unless the rear rotors are removed. Rust and other gunk likes to build up in the parking brake area and can be a source of grinding noises.
Sometimes while moving slow (10-15 MPH), if you apply the parking brake and listen, you can hear if the grinding noise changes. If it does, the parking brake is a likely source for your noise. Myself...I do this once a month anyway just to help keep the PB areas clean.
Old 08-17-2009, 04:18 PM
Front wheel bearings need replaced .. but i can't tell if this noise is coming from them or not. It really sounds like its the rear of the Expedition instead of the front. $300 for front wheel bearing work (both sides).
Old 08-19-2009, 12:11 AM
Front wheel bearings were replaced today and some vibration was fixed. Mechanic diagnosed the rear axle bearings as making the noise in the rear. A total rebuild is soon coming.
Note on the Front Wheel bearings: Shop that did them before didnt pack the bearing right and it almost cost me a spindle (big $$$). I got both wheels done for $239.
Old 08-29-2009, 08:41 AM
Rear axle was cleaned out and totally rebuilt. Nice and quiet ride now! Carriage bearings were worn and making the noise.
Front Brake Disc Rotors, Finding a Cure? Todd Fuller Expedition & Navigator 5 12-31-2016 09:53 PM
Help with bad brakes (long post) Steven Day 1997 - 2003 F150 4 08-18-2015 08:58 PM
Do I need to replace Rear axle Bearings? rickypreston1221 1997 - 2003 F150 5 05-14-2015 01:48 PM
Brake Pad wear noise Jonota 1999 to 2016 Super Duty 4 12-11-2012 08:29 PM
Need Front Brake Help MICHAEL34 1999 - 2003 7.3L Power Stroke Diesel 7 11-26-2010 07:48 PM
Tags
1999, 2006, axle, differential, end, expedition, f150, ford, grinding, noise, problems, rear, rebuilt, seal, seals
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
