Fuel Bowl Diagram
Rodney - That's what I needed. Thanks. Any chance you have a jpg file you could send? And a pic of the other side?
AVTECH12@hotmail.com. Thanks. Reps.
PJwoolw - thanks those images help too. Just so everybody understands - I want to change the fuel heater and the gaskets and valve for the fuel drain. I also have a leak that seems to not be associated with a hose or fitting. Since I shut the truck down once to replace the pump, accumulator, banjo and all hoses and lines associated, this leak is new and I just know that if I don't do it now I'll have a tough time getting motivated to open it all up again. The leak is small though it is persistent and after all, fuel is money. The engine is so close to perfect again, I hate to have this little leak bugging me.
So my plan is to pull the bowl out and work it over top to bottom. Its a cutaway van and there is no direct view into the fuel filter. I pulled the turbo and the air intake tonight and tomorrow I'll try for the fuel bowl.
Kawa - I found and can see the 7/8" bolt. Thanks.
Beans for Pete
I tried to give you some beans for the pics I did not have, of course the FTE site thinks your either full or I have gave too much. pita
