Fuel Bowl Diagram - Ford Truck Enthusiasts Forums
Fuel Bowl Diagram
Old 08-07-2009, 10:18 PM
TPM's Avatar
TPM TPM is offline
TPM is starting off with a positive reputation.
Fuel Bowl Diagram
Anyone have a diagram of the fuel bowl for a 97 7.3L PSD ?
Old 08-08-2009, 03:03 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Lightbulb
Quote:
Is this diagram what are you looking for?
http://rides.webshots.com/photo/2617...96577034htxYhI
Old 08-08-2009, 07:45 PM
TPM's Avatar
TPM TPM is offline
A parts diagram or a picture of the bowl by itself. Thanks for the system diagram.
Old 08-08-2009, 08:23 PM
BlueMule's Avatar
BlueMule BlueMule is offline
BlueMule has a good reputation on FTE.BlueMule has a good reputation on FTE.
Here ya go:
The 1st one is a 94-95 fuel bowl
And the 2nd is a 96-97. You'll see that the filter restriction sensor was moved from the lower rear of the bowl up to the side of the pressure regulator and that the strainer cup under the regulator was eliminated.
Old 08-08-2009, 08:46 PM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE.kawa has a good reputation on FTE.kawa has a good reputation on FTE.
Rodney:
What TPM is looking for is an exploded view of all the parts that make up the fuel filter bowl.
Rog
Old 08-08-2009, 09:08 PM
TPM's Avatar
TPM TPM is offline
Rodney - That's what I needed. Thanks. Any chance you have a jpg file you could send? And a pic of the other side?
AVTECH12@hotmail.com. Thanks. Reps.
Old 08-08-2009, 09:11 PM
TPM's Avatar
TPM TPM is offline
Kawa - the picture helps and a clear parts diagram would also help. I found one on FTE and it was a small image that has not much resolution when enlarged.
Old 08-08-2009, 10:41 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
Here are the three I have.
Old 08-09-2009, 12:00 AM
TPM's Avatar
TPM TPM is offline
PJwoolw - thanks those images help too. Just so everybody understands - I want to change the fuel heater and the gaskets and valve for the fuel drain. I also have a leak that seems to not be associated with a hose or fitting. Since I shut the truck down once to replace the pump, accumulator, banjo and all hoses and lines associated, this leak is new and I just know that if I don't do it now I'll have a tough time getting motivated to open it all up again. The leak is small though it is persistent and after all, fuel is money. The engine is so close to perfect again, I hate to have this little leak bugging me.
So my plan is to pull the bowl out and work it over top to bottom. Its a cutaway van and there is no direct view into the fuel filter. I pulled the turbo and the air intake tonight and tomorrow I'll try for the fuel bowl.
Kawa - I found and can see the 7/8" bolt. Thanks.
Old 08-09-2009, 12:34 AM
pjwoolw's Avatar
Thats what I'm going to do also. I only want to it once ( knock on wood ). Ed at y2k (a sponsor here ) can get get you everything you need at a reasonable price.
Old 08-09-2009, 12:48 AM
TPM's Avatar
TPM TPM is offline
Pete, the link for Ed and Y2K both went no where. Is the a website for Y2K?
Old 08-09-2009, 12:52 AM
pjwoolw's Avatar
Top of the page where is says Ford-Truck sponsors. The site puts those highlights on certain words. There not mine. LOL
Old 08-09-2009, 09:15 AM
DRRXR's Avatar
DRRXR DRRXR is offline
DRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputation
Beans for Pete
Quote:
Originally Posted by pjwoolw View Post
Pete
I tried to give you some beans for the pics I did not have, of course the FTE site thinks your either full or I have gave too much. pita
Old 08-09-2009, 08:35 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Maybe the canister itself is leaking in the bottom, is comun find corrosion there. Just a thougth.
Old 08-09-2009, 10:38 PM
kawa's Avatar
Joseph,
Jose is right. it's probably a good thing that you're planning on pulling the whole filter housing so it can be inspected. If you do have corrosion holes they can be repaired with JB Weld or PM me as I have a spare housing that has been modded for the Super Duty fuel heater.
Rog
Diagrams of fuel bowl housing dougbrown 1994.5 - 1997 7.3L Power Stroke Diesel 20 01-28-2013 01:25 PM
Fuel bowl / fpr .. Small ball? And parts help kyle j 1994.5 - 1997 7.3L Power Stroke Diesel 5 05-17-2012 10:22 PM
DieselSites Fuel Bowl Delete....... MiamiPSD 1999 - 2003 7.3L Power Stroke Diesel 4 04-01-2009 01:26 AM
Glass Bowl Fuel Pumps.... e william 1948 - 1956 F1, F100 & Larger F-Series Trucks 35 02-03-2009 07:03 PM
Fuel flow diagram. Flea 1994.5 - 1997 7.3L Power Stroke Diesel 3 08-19-2008 02:45 PM
Tags
73, 73l, 97, bowl, diagram, f250, filter, fuel, heater, leak, line, location, pics, powerstroke, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
