Fuel Bowl Diagram
Old 08-07-2009, 09:18 PM
TPM's Avatar
TPM
TPM is offline
Fuel Bowl Diagram
Anyone have a diagram of the fuel bowl for a 97 7.3L PSD ?
Old 08-08-2009, 02:03 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Lightbulb
Is this diagram what are you looking for?
http://rides.webshots.com/photo/2617...96577034htxYhI
Old 08-08-2009, 06:45 PM
TPM's Avatar
TPM
TPM is offline
A parts diagram or a picture of the bowl by itself. Thanks for the system diagram.
Old 08-08-2009, 07:23 PM
BlueMule's Avatar
BlueMule
BlueMule is offline
Here ya go:
The 1st one is a 94-95 fuel bowl
And the 2nd is a 96-97. You'll see that the filter restriction sensor was moved from the lower rear of the bowl up to the side of the pressure regulator and that the strainer cup under the regulator was eliminated.
Old 08-08-2009, 07:46 PM
kawa's Avatar
kawa
kawa is offline
Rodney:
What TPM is looking for is an exploded view of all the parts that make up the fuel filter bowl.
Rog
Old 08-08-2009, 08:08 PM
TPM's Avatar
TPM
TPM is offline
Rodney - That's what I needed. Thanks. Any chance you have a jpg file you could send? And a pic of the other side?
AVTECH12@hotmail.com. Thanks. Reps.
Old 08-08-2009, 08:11 PM
TPM's Avatar
TPM
TPM is offline
Kawa - the picture helps and a clear parts diagram would also help. I found one on FTE and it was a small image that has not much resolution when enlarged.
Old 08-08-2009, 09:41 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Here are the three I have.
Old 08-08-2009, 11:00 PM
TPM's Avatar
TPM
TPM is offline
PJwoolw - thanks those images help too. Just so everybody understands - I want to change the fuel heater and the gaskets and valve for the fuel drain. I also have a leak that seems to not be associated with a hose or fitting. Since I shut the truck down once to replace the pump, accumulator, banjo and all hoses and lines associated, this leak is new and I just know that if I don't do it now I'll have a tough time getting motivated to open it all up again. The leak is small though it is persistent and after all, fuel is money. The engine is so close to perfect again, I hate to have this little leak bugging me.
So my plan is to pull the bowl out and work it over top to bottom. Its a cutaway van and there is no direct view into the fuel filter. I pulled the turbo and the air intake tonight and tomorrow I'll try for the fuel bowl.
Kawa - I found and can see the 7/8" bolt. Thanks.
Old 08-08-2009, 11:34 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Thats what I'm going to do also. I only want to it once ( knock on wood ). Ed at y2k (a sponsor here ) can get get you everything you need at a reasonable price.
Old 08-08-2009, 11:48 PM
TPM's Avatar
TPM
TPM is offline
Pete, the link for Ed and Y2K both went no where. Is the a website for Y2K?
Old 08-08-2009, 11:52 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Top of the page where is says Ford-Truck sponsors. The site puts those highlights on certain words. There not mine. LOL
Old 08-09-2009, 08:15 AM
DRRXR's Avatar
DRRXR
DRRXR is offline
Beans for Pete
Originally Posted by pjwoolw
Pete
I tried to give you some beans for the pics I did not have, of course the FTE site thinks your either full or I have gave too much. pita
Old 08-09-2009, 07:35 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Maybe the canister itself is leaking in the bottom, is comun find corrosion there. Just a thougth.
Old 08-09-2009, 09:38 PM
kawa's Avatar
kawa
kawa is offline
Joseph,
Jose is right. it's probably a good thing that you're planning on pulling the whole filter housing so it can be inspected. If you do have corrosion holes they can be repaired with JB Weld or PM me as I have a spare housing that has been modded for the Super Duty fuel heater.
Rog
Quick Reply: Fuel Bowl Diagram
