Transmission Bolt Pattern
Hello everybody this is my first post. I am working on my son's Ranger and I have a few questions. I need to replace the tranny. I have a 5 speed with a tag no. F27A-XA 3.0 l engine. I have been researching and I need to know one thing. I found a M50D-R1 with a 2.3 L engine. Is the bolt pattern the same on both trannys? Or is the M50 different for each size engine? This would be hepful. And there is talk about a speed sensor. Any Answers?
Thanks!
Thanks!
Each of the engines (2.3,3.0,4.0) have different bellhousing bolt patterns and will not interchange. Some of the 5 speeds have removable bellhousings. If your trans does you could put your bellhousing on the replacement trans. One thing to consider though is that transmissions tend to have different ratios, stronger bearings, and stronger gears on the larger engines. So even though it may look the same, you might end up putting in a weaker transmisson.
The 2.9 bellhousing will not work. The 2.9 is a larger version of the 2.8 cologne engine which later became the 4.0. The 2.8/2.9/4.0 bolt patterns are the same but they are the only ones that will. The ford lima engine started out as a 2.0, became the 2.3, and later ended up being bored out to a 2.5 and they have the same bolt pattern as they are the same design. Aside from the 2.5 and 2.0, the 2.3 lima doesnt share a bolt pattern with any other engine as far as I know. I know for a fact that they wont interchange with any v-6 engine thats in a ranger.
It will bolt in but I believe they switched from using a cable operated speedometer to electric around '93. Instead of being driven by the trans, the electric speedometer uses a sensor on the rear differential so the hole in the transmission for the speedometer drive is not there. You should be able to remove the tailshaft housing and bolt yours on with the speedometer drive unit. Only four bolts hold it on so it is not a difficult task.
Its sounds like I might have a good one . Just got off the phone with him. He has only had it since middle of July. I took some pics to compare. I have did the research and it looks fairly conclusive with what you said. Going to crawl under their and check out the
tailshaft housing. Should I take a wrench and open the drain plug. Thats all I have now.
Thanks
Thanks
I am going to check the fluid out.Want to see if there is any burn smell or real black color. Will the starter have to be removed? It looked like it is
attached to the tranny. When you break loose the tailshift is there any gasket or silicon going back on? Thanks
Well looks like i can find out my anwser hear as well, we have 88 2.3 2wd ext cab with 5 speed, was looking at are local parts yard and came up with 2.0 reg cab and about a 1990, Im thinking from my younger years they are the same bolt pattern right ? also would i have to change anything else ? thanks any and all help.
You should be able to find the answer. It is right above. The 2.3 is common with 2 other ones. I have a link which I will send. I do not know how to shorten it up though. By the way I am no exert on this at all. The post by the other member were very helpful.
[URL="http://www.therangerstation.com/tech_library/ManualTransmission.html
Hey Johncfox I got the transmission today! Looks real clean and oil smells good.When I take that tailshaft off is there a gasket or use silicon or nothin?
What is under that a bearing or something? That will get me started Think I will start new post. Thanks
eveready77
06-22-2010 06:46 PM
BroncoRoadKill
02-08-2004 12:38 AM
