Differential/Tcase tag decode
Old 08-07-2009, 06:18 PM
hogworkzinc's Avatar
hogworkzinc
hogworkzinc is offline
Dentside-aholic Supporter
Hello all & thanks in advance for the help. I have some tag numbers that I need help decoding.
These are from a 79 ish ford p/u. F150
Front axle differential tag: top line, 4 09 D9TA BCB
bottom line, 610068-3
Front axle differential web: 44 9F
Rear axle differential tag: top line, 3 54 D8TA ADA
bottom line, 603900-12
Rear axle differential web: 60 C-30255
Transfer case tag: top line, D9TA7A195 VA
bottom line, 3 17 79 205 66
I'm guessing the front axle is a Dana 44 w/ 4.09 gears & the rear is a Dana 60 w/ 3.54 gears. That's if both are unmolested. I know these axles were swapped in (8 lugs) & are not the originals. Anyway to verify what the gear ratios are? If these are whats really in it, there is no way the 4x4 will work w/out grenading the t/case.
Transfer case NP 205?
Thanks again for the help.
I also have this listed over in the clutch/axle/tcase/differential forum. But i know alot of guys over here know alot about these things too.
Old 08-07-2009, 07:11 PM
Jermafenser's Avatar
Jermafenser
Jermafenser is offline
D9TA-BCB = 1979 Dana 44-9F front axle / 4.09 ratio / 3500 lb capacity / free running hubs / non-locking differential
D8TA-ADA = Dana 60 3.54 ratio, open differential - used on 1978/79 F250, excluding crew cabs. Takes 1350 joints.
You can identify the transfer case by looking at it.
dlr71
Delaware Chapter
121
09-28-2023 04:56 AM
EndorphinJunky
Ford Truck Parts for Sale
26
01-12-2017 01:58 PM
cigarxtc
05-12-2011 02:26 PM
spow1998
04-13-2011 12:01 PM
captrivers
05-24-2010 09:40 AM
Quick Reply: Differential/Tcase tag decode
