disable seat belt alarm - Ford Truck Enthusiasts Forums
Old 08-07-2009, 10:09 AM
bergeron bergeron is offline
bergeron is starting off with a positive reputation.
I just purchased a 2004 Excursion and I want to disable the seat belt alarm.The truck didn't come with an owners manual so I got the manual from my 2005 (yea, I am a glutton for punishment) and followed the instructons but it wouldn't disable the alarm. It worked fine on the 2005. Can anyone help me out with instructions for a 2004? Thanks in advance.
Old 08-07-2009, 12:01 PM
tdappleman tdappleman is offline
tdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to all
Here's a link where you can get the actual owner's manual for your truck. I believe the instructions are all the same but the timing is critical and may need to be repeated if it doesn't work the first time.
https://www.fleet.ford.com/maintenan...ls/default.asp
Here's the text from my 03 manual:
Deactivating/activating the BeltMinder feature
Read steps 1 - 9 thoroughly before proceeding with the deactivation/activation programming procedure.
The BeltMinder feature can be deactivated/activated by performing the following procedure:
Before following the procedure, make sure that:
• The parking brake is set
• The gearshift is in P (Park) (automatic transmission)
• The ignition switch is in the OFF position
• All vehicle doors are closed
• The driver’s safety belt is unbuckled
• The parklamps/headlamps are in OFF position (If vehicle is equipped with Autolamps, this will not affect the procedure.)
To reduce the risk of injury, do not deactivate/activate the Belt Minder feature while driving the vehicle.
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1–2 minutes)
• Steps 3–5 must be completed within 60 seconds or the procedure will have to be repeated.
3. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled. This can be done before or during BeltMinder warning activation.
4. Turn on the parklamps/headlamps, turn off the parklamps/headlamps.
5. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled.
• After step 5 the safety belt warning light will be turned on for three seconds.
6. Within seven seconds of the safety belt warning light turning off, buckle then unbuckle the safety belt.
• This will disable BeltMinder if it is currently enabled, or enable BeltMinder if it is currently disabled.
7. Confirmation of disabling BeltMinder is provided by flashing the safety belt warning light four times per second for three seconds.
Last edited by tdappleman; 08-07-2009 at 12:21 PM. Reason: Added text for deactivating the Beltminder feature.
Old 08-07-2009, 01:20 PM
TeamMudd TeamMudd is offline
TeamMudd is gaining momentum as a positive member of FTE.TeamMudd is gaining momentum as a positive member of FTE.
not to say those don't work........... BUT, there's a little grey plug under the seat......... UNPLUG IT.
some will say this has to do with the electric control seats. so far i've disabled all of our work trucks, 05 F550 (electric seats), and (2) 03 F250's (also electric seats) with a simple unplug of a connector. there are typically TWO conectors under the seat, one for the electric controls and one that closer to the seatbelt (female end by your right hip). it may be a trick to find at first, but it will do the trick. all the ones from the trucks i listed above are a grey colored plug.
i did the same thing on my 02 Ex (XLT non-electric seats), and my F250 Lariat (electric seats), no more alarm, and WAY less time!
Old 08-07-2009, 02:09 PM
I tried that on my 99 Expedition and the light just stayed on all of the time - no chime... but I didn't like the light being on. Not sure if the results would be the same here - but it only takes about 1 minute to do it the right way.
Old 08-07-2009, 02:35 PM
Thanks to tdappleman...the instructions for your 03 worked. They were entirely different from the 05. Thanks again
Old 08-07-2009, 03:07 PM
You're welcome - looked at the 05 out of curiosity and the number of times you do each item is different. Good to know!
Old 08-07-2009, 06:43 PM
housedad's Avatar
housedad housedad is offline
housedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputation
Sometimes a proper application of a 12 ga shotgun will make the alarm shut up, too.
I ahve felt like that many times....
Old 08-07-2009, 07:21 PM
no light stays on in any of my vehicles or the shop vehicles.
i guess it's 6 of one or 1/2 dozen of he other......... but to find a plug push the tab, and unplug worked alot quicker on all of my vehicles. on another note i've also done this on my brother-in-laws 05 F150, their 04 windstar, and none of them had the light stay on. that may have been an Expy trait..... dunno?
Old 02-08-2015, 06:43 PM
Xryen Xryen is offline
Xryen is starting off with a positive reputation.
Can you give me those instructions for the 2005??? I guess I've been following the wrong ones also.
Old 02-08-2015, 06:46 PM
Jmatthews's Avatar
Jmatthews Jmatthews is online now
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
that's what I did 14 years ago, still works.... Err, doesn't work?
Seat belt chime (Disable) DOOM173 Excursion - King of SUVs 9 02-20-2016 11:23 AM
Disabled Backup/RSS Alarm Laserman 1999 to 2016 Super Duty 0 09-14-2015 06:54 PM
seat belt chime hogryder007 1999 to 2016 Super Duty 8 11-27-2014 10:32 AM
Disable the seat belt alarm when buckling-up does not do it - '03 Explorer APMski Explorer, Sport Trac, Mountaineer & Aviator 3 11-02-2014 04:45 PM
05 aviator, seat belt alarm is killing me! frank457 Explorer, Sport Trac, Mountaineer & Aviator 15 02-17-2014 01:33 PM
Tags
04, 2003, 2006, alarm, belt, chime, codes, disable, expedition, explorer, f250, ford, seat, seatbelt, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
