dry gas in diesel?
Old 08-07-2009, 08:25 AM
wildstang's Avatar
wildstang
wildstang is offline
VT Chapter Ldr
dry gas in diesel?
is it safe to put dry gas in diesel and run it through the engine? I think I had a water issue, truck ran like crap for a few days until I drained canister and put in new filter. I was told to run some dry gas to clean out any water left in the rails or lines. Thanks.
Old 08-07-2009, 11:44 AM
kawa's Avatar
kawa
kawa is offline
Hmmmmmm, I think that "Dry Gas" is an alcohol product and IIRC...alcohol in our fuel systems is a NO, NO!
Rog
Old 08-07-2009, 10:20 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
x2 but my old Jetta diesel said it was OK to use a 'little' gas in the winter if you had to for gelling problems. I would just use dieselclean.
Old 08-08-2009, 02:15 AM
joe_13894's Avatar
joe_13894
joe_13894 is offline
No, absolutely never put the stuff in a diesel engine. It will kill your injectors. It absorbs the water, and then when the water / methanol mix meets the injector tip, it flashes to steam. When it does, the steam eats up the injector tips.
Our engines have a water separator on them as part of the fuel filter. Let the separator do it's job and remove the water.
1993 ford
05-06-2017 01:48 PM
MagicMtnDan
2017+ Super Duty
15
03-18-2017 03:11 PM
Syncrowave
19
10-31-2016 09:08 PM
killergsxr1
12-31-2015 09:49 AM
crp2000eb5.4
1997-2006 Expedition & Navigator
28
01-18-2008 07:48 AM
Quick Reply: dry gas in diesel?
