put on air intake and sometimes it effective and sometimes when accelerating it hits a restrictive feel and takes a while to know wheather or not to accelerate more or drop a gear. what this hesitation? seems to happen during hot time of day. worse with a.c on too.
my K&N does it when its hot and when its cool it works fine. Im going to get a new hood with a scoops or somthing to get the air in thier better and get the heat off the engine more effectively
i changed my gas from arco to chevron and it improved noticably. going to try 89 chevron gas this week. trial and error. more air in more octane for the mix right. like the hood with scoop idea
well im running with mine a k&n cai, flowmaster 40 series, and diablosport predator tune. running 93 octane on my 4.6 it runs good till its hot then its little slower then what it would be cold so i plan on headers and gear swap to 4.10s and then try the hood idea. it all should work pretty well together
Any of the open element air filters like the FIPK and Airaid etc are a waste of time. The suck in warm/hot air and if the MAF is near the filter the turbulent air from the fan effects the MAF readings. The stock air box is better since it gets cooler air. In most cases the stock air box flows enough for the motor unless the motor has been significantly modified and even then it may be fine. Your better off with a free flow filter that fits the OEM air cleaner. So to answer your question, yes there is something that can be done about it, put the air intake setup on craigslist. I also noticed when I had an FIPK on my truck that the fuel economy wasn't as good either.
HOW DARE YOU!! I gained at LEAST 1hp, 1mpg better, and my throttle hesitation went away completely with my K&N CAI! Except for when the engine warms up, on days it gets over 80-degrees, going up hills, or when the oil gets the MAF dirty. It will pay for itself in 6 years unless I have to buy the cleaning kit which will add another year to it, and if the weather stays cold enough
(I don't really own a K&N CAI, but I did back in 2003. It went in the garbage after a month)
your MAF should not get oily from the K&N unless its over oiled. When you clean the filter just mist the oil onto the filter, let it dry, mist again. This will allow for correct oiling of the filter.
I've found that the Gotts mod is actually more effective than a CAI. I did it and installed a K&N filter and love the effect. Still get cooler air from the fender well not the engine compartment
If you do an online search for “air filter test” there is a lot of very good information. IMHO, the CAI units are NOT WORTH THE $$! Unless you are talking about a system that was specifically designed for a specific application there are very little hp/tq gains actually achieved in a street use vehicle and there are very few docs that these mfg’s can produce that actually show an increase in hp/tq in the power-band range of a relatively stock street vehicle.
I would avoid oil impregnated filters. While they have their purpose in off-road applications, Ford/GM/Dodge all have “watch-out” bulletins where the oil has contaminated intake sensors. - they even have a training video for the tech's on this (flatratetech.com) .
If you look at the flow data, WIX HP filters flow 98+% of K&N and have a much smoother flow post filter plus excellent filtering, for a fraction of the price! The OE’s have an excellent air intake system the only issue that really exists is the plastic intake tube with it’s noise canceling design- that does reduce the intake efficiency a little but makes it very quiet!. You can use a WIX OEM HP replacement filter in the OEM plastic manifold box and either remove the plastic tube and replace it with a piece of pipe/hose, etc or remove the tube completely and replace the tube by building an air ram type intake into the air box manifold (where the pipe use to attach)- make sure ti terminates above the fan shroud to avoid water intake or fan induced pulsations.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
just do like i did. I took the stock piping off and got a 4" flexible dryer duct and ran it from a 3" pvc pipe to the stock intake box. Works pretty good.
__________________
2006 Ford F150 Ext cab, long bed, 4x4, 4.10 w/ limited slip, 5.4L triton, K&N filter, 2.5" AS leveling kit, 1 chamber mufflers with 45* 4" tips out to the side, 17x8 eagle alloy bullet holes, 20% tint, 305/70/17 nitto a/t's
Ok... And what exackly is this "Gotts mod" we're talking about here?? I agree the stock intake tube does look a bit odd. Do you totally get rid of it or what?
__________________
06 SUPERCREW XLT, 1"DAYSTAR BUDGET BOOST LEVEL KIT, SCT X3 FROM MIKE AT 5STARTUNING, E-FANS FROM TROYER PERFORMANCE, DUAL CATBACK EXHAUST, S&B CAI FROM 5STAR, 285/70/17 NITTO TERRA GRAPPLERS, TRUXEDO LO-PRO QT BEDCOVER, CHAMPION ONE-PIECE SPARKPLUGS. HAPPY TO BE DRIVING THE BEST TRUCK ON THE ROAD.
