Largest tires on '91 F350 without lift - Ford Truck Enthusiasts Forums
Old 08-06-2009, 09:49 PM
No_BS's Avatar
No_BS No_BS is offline
No_BS is starting off with a positive reputation.
My 350 has plenty of power now with the stock 460, T18, 3.55's and 235/85's but I was just wondering what is the max tire size that will fit with stock suspension. It's mostly a tow/haul vehicle so off road performance is negligible. I'm planning on regearing to 4.10's with the tire size change. I don't really want to lift it because it is a tow rig mainly. It'll have a ZF5 by the time this is done. Thanks.
Old 08-06-2009, 10:31 PM
Hokiewheeler Hokiewheeler is offline
Hokiewheeler is starting off with a positive reputation.
33s for sure, possibly 35s. 35s should fit, but in my experience they don't always. It depends on the brand and the actual size of the tire. I've seen 35 inch BFG's mounted without doing anything and others that have had to trim or shim the bumper. Your mileage may vary.
Old 08-06-2009, 10:37 PM
No_BS's Avatar
A bit of trimming doesn't bother me. Mileage is horrible as is so neither does that.
Old 08-07-2009, 12:07 AM
guitarnik's Avatar
guitarnik guitarnik is offline
guitarnik is starting off with a positive reputation.
i have 33x12.5 on my stock f250 and the front springs are saggin. it depends on how wide you go, i seen a guy with 37s on a stock 350 with just moving the bumper a little. but then another tire might just barely clear 35s, also the backspacing of the wheel matters
Old 08-07-2009, 12:17 PM
Jermafenser Jermafenser is offline
Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.
The 35s should clear without issues. I put 36s on my '97 F350, no problems...with stock steel wheels, even.
Old 08-07-2009, 01:52 PM
No_BS's Avatar
I really would like to put on the newer style of H1 tires when I do. I don't mind a bit of modification to the front bumper I'm just worried about how much it will affect the steering. Do you have major issues with the tires hitting the springs with 36's? Turning radius is already bad, not really looking to make it much worse.
Old 08-07-2009, 02:54 PM
Quite a few of us have done that route - do a search and see the opinions.
As for me...no real issues...yet.
I have good clearance between the tires and springs. They will rub lock-on-lock.
The steering isn't bad, but since my truck has sloppy steering to begin with, it has magnified the sloppiness. The 36s won't be there much longer, anyway. I'm going back to stock when I buy new tires.
Old 08-07-2009, 07:29 PM
bmf316's Avatar
bmf316 bmf316 is offline
bmf316 is starting off with a positive reputation.
go with 33's or it will look stupid and crammed
Old 08-07-2009, 09:09 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
Heres some pics of my F250 w/ 36" tires and no lift. All i had to do to get them to fit was remove the front bumper. (Already had the custom one made, so that wasnt a problem for me.)
Old 08-07-2009, 10:46 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
What he said. 35's may "fit" bit looked stuffed.
Old 08-08-2009, 01:43 AM
wantaford's Avatar
wantaford wantaford is offline
wantaford is starting off with a positive reputation.
33's for sure - that is what I run on my F350, check out my gallery.
Old 11-01-2009, 01:17 AM
landon460 landon460 is offline
landon460 is new and has a neutral reputation at this point.
I had 39" Mickey Thompson's on my 96 F350 4x4 with only a 3" body lift and custom front bumper to prevent rubbing issues. Just for reference is the purpose of telling you that but I would stick with a decent 33" tire like Wild Country TXR or RVT radials.
Old 11-02-2009, 06:38 AM
kdy72601's Avatar
kdy72601 kdy72601 is offline
kdy72601 is starting off with a positive reputation.
285/75/16 it a 33/11.00 fits perfect no rubbing no trimming, might have to space the bumper out a inch. my pretty much stock 460 with 4.10's will burn'em no problems
Old 11-02-2009, 05:42 PM
97FRD1TN's Avatar
97FRD1TN 97FRD1TN is offline
97FRD1TN is starting off with a positive reputation.
I have 35s on 10in wide wheels on my stock 97 F350 and no rubbing on the springs or anything,just a little trimming on the bumper.Also the tires if anything still look small on my truck and are by no means crammed on.
Old 11-02-2009, 08:41 PM
DarrinGT's Avatar
DarrinGT DarrinGT is offline
DarrinGT has a good reputation on FTE.DarrinGT has a good reputation on FTE.
As has been said, the 35's fit nicely, better on a 91 body style than a 92 and up because the bumper doesn't come back as far. No trimming is necessary.
2016 f350 - stock suspension with 33's ? Hedgehog1 1999 to 2016 Super Duty 6 06-06-2016 10:00 AM
2002 F350 4X4 Rubbing on Leaf Springs - Increase tires size + lift kit CanadianBlake 1999 to 2016 Super Duty 3 06-02-2012 11:49 AM
F350 4x4, what size tires? Jimbo302 1987 - 1996 F150 & Larger F-Series Trucks 8 04-24-2011 12:39 PM
Tire Experience Needed - ~35"'s and Towing 8,000lb keithc 1999 to 2016 Super Duty 15 05-26-2010 01:04 PM
2003 F350. Lift/TowingTire Questions Fordevr 1999 to 2016 Super Duty 12 05-24-2010 05:19 PM
Tags
1990, 33, 33x125, 350, 35s, big, biggest, f250, f350, fit, ford, road, size, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
