How can I increase fuel mileage in 02 5.4 Expedition - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 08-05-2009, 10:03 PM
rlewis581 rlewis581 is offline
rlewis581 is starting off with a positive reputation.
What is the best fuel mileage anyone has gotten from an 02 5.4 expedition and how.
Old 08-05-2009, 10:18 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
One time on a round trip I averaged 53 MPG by going only downhill both ways.
Old 08-06-2009, 12:28 AM
97ExpGuy 97ExpGuy is offline
97ExpGuy is gaining momentum as a positive member of FTE.
Tune up. New coils, plugs, and injectors. Maybe look into a K&N air intake system and a new fuel filter. Make sure tires are aired up all the way, etc. Other than that, a consistent cruising speed down the highway (65-70 mph) should net you nice results. On my first run I got 17mpg going down I-44 from St. Louis to Joplin. That was a loaded vehicle, AC on, and two buddies at 65 mph. Not too shabby. On the way home it was around 15 mph and I believe that's due to driving back uphill.
My average around town mileage is about 13-13.5 mpg. I have a 26 gallon tank and if I top it off good I can squeeze about 325 miles out of it - and that's with the Low Fuel light on.
Old 08-06-2009, 12:58 AM
bc11 bc11 is offline
bc11 is starting off with a positive reputation.
I've heard the K & N filters help. Other than that, drafting up close behind tractor trailers may save a couple mpg if you don't mind risking your life while tailgaiting a truck.
Old 08-06-2009, 05:36 AM
TimGinCentralNJ's Avatar
TimGinCentralNJ TimGinCentralNJ is offline
TimGinCentralNJ is starting off with a positive reputation.
"What he said"
I've gotten as high as 18 mpg (which is pretty damn good for a truck rated at a "best case" of 17 mpg) on my way to Toronto with 4 adults and luggage. Tires were set to 36 psi all around and I had the cruise set to 65-70 mph.
Maintenance items (which were mentioned earlier) notwithstanding, the biggest mpg killers on these trucks seems to be 'stop and go' driving conditions, traveling at over 70 mph and of course...being too heavy on the pedal.
If you drive it like you're gas gauge is on "E" and there's no gas station to be seen, you'll probably be as surprised as I was how efficient these trucks can be if you watch what you're doing.
Hope that helps,
Tim
Old 08-06-2009, 09:46 AM
fiveohpoepoe's Avatar
fiveohpoepoe fiveohpoepoe is offline
fiveohpoepoe is starting off with a positive reputation.
I was averaging between 10.8 and 11.4 in town with my 99 EB 5.4. I put a single Flowmaster on, complete tune up and K/N. I didnt notice any change. I since added 2" and 33,s. I then put the performance tune[Superchips 1715] and I run 89 octane.
I steadily saw the mpg rise and on a trip to Myrtle Beach,SC[roughly 260-ish miles] Combined hwy and two lane roads I averaged 15.7. Running between 55 and 75 with the a/c full blast.
While in MB, I averaged 14.2-14.6. I was blown away.Since I have been back, Im still in the lower 14 range.
I do the numbers on my own and watch the overhead.
Old 08-06-2009, 12:39 PM
TexFinn TexFinn is offline
TexFinn is starting off with a positive reputation.
"How can you increase fuel mileage in 02 5.4 Expedition?", you ask? Well..., the best method is by not driving it.
Yeah, yeah... I know... That was not funny...
The best I ever got from my 00 5.4 EB was around 21mpg on highway. On the current 04 I've gotten as good as 22mpg. Around town, no matter what you do, it's between 13-14mpg.
Lots of good suggestions here already regarding things to do (tune-up, free flowing intake/exhaust, drafting etc.), but one thing to also keep in mind is do what hypermilers do: use your brakes as little as possible. Especially in city driving.
I try to do that sometimes, but never have enough patience to do it consistently. But I've heard/read that it helps.
Old 08-06-2009, 07:27 PM
ExpySport ExpySport is offline
ExpySport is starting off with a positive reputation.
The best I have ever gotten was 17.4mpg and that was on an all highway run with the usual stop-n-go for the toll plazas. I had the Expedition filled with gear, 4 people and a black lab. Since then, I have achieved similar results on the same trip. Around town, I am averaging between 12-13mpg. All mentioned tips are excellent to increase fuel mileage. At the time I got the 17.4mpg, I was running load range C tires and had them inflated to 40psi. I had to replace the tires about 5 months ago, and I have done the same highway trip a few times. The new tires are Standard Load all-seasons and I got the same 17-18mpg. Had them inflated to 35psi. I do usual maintenance and the truck is all stock. Basic air cleaner, stock exhaust, no chips or power adders. For as heavy as these things are, I am more than happy when I get anything over 15mpg.
Old 04-06-2014, 04:28 PM
osucharger osucharger is offline
osucharger is starting off with a positive reputation.
Don't forget alignment. That's a biggie. So, free flowing in, good spark, free flowing out, and a light foot. Anything you purchase to help that will improve mileage. Troyer Performance has some sweet add ons. Under drive pulleys, and the kicker is electric fan.
Old 04-06-2014, 08:05 PM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is online now
alwaysfords41 is gaining momentum as a positive member of FTE.
The dude has posted 6 times in 4.5 years, lost this vehicle 3 years ago, I don't think he is coming back for your advice.
Old 04-08-2014, 12:09 PM
Mark T-TB's Avatar
Mark T-TB Mark T-TB is offline
Mark T-TB is starting off with a positive reputation.
Quote:
Probably took the advice above "don't drive it"
Old 06-30-2016, 11:30 AM
Battletoad79 Battletoad79 is offline
Battletoad79 is starting off with a positive reputation.
He may not be coming back but others who search for the same information would like to see what others have posted.
Programmer for 2 xtamer 1999 to 2016 Super Duty 1 11-16-2016 10:03 AM
where is the fuel filter in 2003 expedition chubbybubby 1997-2006 Expedition & Navigator 5 11-26-2011 05:53 PM
06 Expedition fuel mileage 06 EXPD 1997-2006 Expedition & Navigator 8 01-17-2011 04:44 PM
Injector replacement 02 5.4 F16Driver 1997-2006 Expedition & Navigator 4 03-21-2010 02:17 PM
fuel filter rmatejczyk 1997-2006 Expedition & Navigator 11 06-26-2003 08:23 AM
Tags
2000, 2001, 2004, 54, 99, bauer, drive, eddie, expedition, ford, fuel, gas, increase, increasing, light, mileage, miles, mpg
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
