2.3 timing - aux. sprocket??? 1989
Old 08-05-2009, 07:27 PM
fairlaniac's Avatar
fairlaniac
fairlaniac is offline
Here is a picture of my engine. The aux. sprocket has a timing point on it (look for the red "X"), does that align with anything for proper timing? I have a '95 Ford service manual and it shows on a '95 Ranger 2.3 there is a timing mark on the cover that aligns with the diamond shaped mark on the aux. sprocket. I just want to be sure that my '89 does or does not get aligned with any other mark? I disturbed the sprocket when I accidentally rotated it with the belt off.
Thanks,
Old 08-05-2009, 09:59 PM
michigan66's Avatar
michigan66
michigan66 is offline
As near as I can determine from reading about camshaft timing and belt installation in my '91 Ranger Truck Shop Manual, the key step reads: "Position the crankshaft sprocket to align with the TDC mark and the camshaft sprocket to align with the camshaft timing pointer." I do not find any reference to aligning the auxiliary sprocket with anything, even though your picture shows a mark on that sprocket. It looks like Ford used the same sprocket on the camshaft and auxiliary shaft.
I'd say, "Don't worry about it."
Old 08-05-2009, 10:09 PM
86bigred's Avatar
86bigred
86bigred is offline
Isn 't that the sproket for the distributor. Your 89 still has a distributor.
Old 08-06-2009, 05:48 AM
fairlaniac's Avatar
fairlaniac
No distributor
'89 has no distributor. Without tearing the engine completely apart, I'm assuming the aux. sprocket drives the oil pump and that's it?
Thanks,
Old 08-06-2009, 08:11 PM
86bigred's Avatar
86bigred
86bigred is offline
ok now i know.is there a counter balance shaft on these 2.3's.i'm new to these engines sorry.just hate to see fairlanaic get this together and be out of balance,plus it's a learning experience for me.
Old 08-11-2009, 09:07 AM
GregAlex47's Avatar
GregAlex47
GregAlex47 is offline
I just replaced my belt also and had the same problem. My Hanes manual shows that Aux. Gear lines up with the camshaft gear when the camshaft gear is set. So it points toward the Camshaft timing mark, and it is the gear for the Oil Pump. Hope that helps.
MATTwGrandpas77
07-30-2017 07:24 PM
Martin Torres
05-20-2017 09:41 PM
tobyw
08-31-2015 01:01 PM
tobyw
4 Cylinder Engines
08-25-2015 02:53 PM
Jim88554
1997 - 2003 F150
11-17-2008 05:39 AM
Quick Reply: 2.3 timing - aux. sprocket??? 1989
