Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-05-2009, 06:35 PM
Dogwater Dogwater is offline
Dogwater is starting off with a positive reputation.
Change out motor in Ford Lightning
Hi All. This will be my first post. I have a 2001 Lightning. I lent it to a buddy so he could get to and from work for a week. I guess he felt he had to blow up the motor, so he did . The mechanic said it threw a rod and the rest is history...I can't blame my buddy; who knows what was wrong when I handed him the keys, right? (Besides, he has no money).
So, as I plan to keep the truck forever, I had a "brilliant" thought. Why not debadge the lightning and put in a large crate motor? Something different on the road. We'll call it the "Thunder" or something.
I'm not worried about resale, since it won't be sold. My question then, is it possible to do this? What are the issues with the computer, tranny mounting, engine mounts? Any advice will be appreciated!
  #2 (permalink)
Old 08-05-2009, 09:52 PM
S.A.L. S.A.L. is offline
S.A.L. is starting off with a positive reputation.
GT500 crate motor.
Why de-badge?
Stay with the Modular engine family.
Visit NLOC.net and post your question in the Gen2 section.
  #3 (permalink)
Old 08-05-2009, 11:02 PM
Deluxe05's Avatar
Deluxe05 Deluxe05 is offline
Deluxe05 has a very good reputation on FTE. Deluxe05 has a very good reputation on FTE. Deluxe05 has a very good reputation on FTE. Deluxe05 has a very good reputation on FTE.
Welcome aboard, Dogwater. There is a wealth of information here on FTE. You might do some searching in the 1997 - 2003 forum which is just above this one in the forums listing.
Also, you may consider going over to the National Harley Truck Owners Club forum, and posting over there. In this case, it is pretty active on the F150 side...which should work in your favor.
Good luck!!
__________________
Semper Fi
"Some people live an entire lifetime and wonder if they have made a difference in the world. Marines don't have that problem." - Ronald Reagan
  #4 (permalink)
Old 08-06-2009, 03:32 AM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
The automatic transmission needs a signal from the computer to work. Although there are aftermarket controllers around. Have you ever considered dropping a 5.4 crate in, maybe a nice Supercharged 32V DOHC 5.4?
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #5 (permalink)
Old 08-06-2009, 05:41 PM
UrbanXX's Avatar
UrbanXX UrbanXX is offline
UrbanXX is gaining momentum as a positive member of FTE. UrbanXX is gaining momentum as a positive member of FTE.
If I were you I would check the local junk yards and get an engine out of a Lincoln Mark Vlll, use everything on your existing engine that will fit.
The Lincoln Mark Vlll engine should be easy to find due to the fact of the air ride going bad and they get trashed.
You will still have quite a bit of power.
I would not debadge the truck if I were you.
  #6 (permalink)
Old 08-06-2009, 07:04 PM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of
It would be cheaper to just get a built 5.4 block,,put an bigger aftermarket blower on it,ported heads and performance cams.
You can make all the power you want!
__________________
Phil
2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams
L-conversion/Kenne Bell upgrade blower at 16 PSI
BTS/4R100 tranny/100 shot nitrous
1.68 60' time/11.76 @ 116.17
  #7 (permalink)
Old 08-06-2009, 08:23 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
Never fry bacon NAKED!
2002 Ford F-250
My Garage
Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold
Quote:
I can understand you suggesting NLOC like you did, but why would he want to check out the N/A F150 forum here? He has a Lightning, not a N/A F150, and upgrading to a built engine in a Lightning is a lot more common than N/A F150's.
Not trying to be a jerk, just trying to understand.
Quote:
Again, dropping a built engine into a Gen 2 Lightning is very common. He won't need an aftermarket controller of any kind, unless he changes from the 4R100 in his truck.
To the OP, where do you live?
JJ at Woodbine Motorsports has built engines taylored to your needs, as does JDM who is very reknowned for the engines he produces, from the "regular" built long blocks to the 32V monsters that come from his shop.
A lotta guys swear by JLP, and there's a place in Houston, PSI, that's cranking out some pretty baddass Lightnings...coughcoughchadcoughcough...
The guys from NLOC know who I'm talking about!
Stewart
__________________
The Brotherhood of FTE <~click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
2002 PSD F250 SC 4x2: 38R, AC codes, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody
2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
  #8 (permalink)
Old 08-17-2009, 12:48 PM
Deluxe05's Avatar
No offense taken....not everyone has the same thought process!
It is no secret that the standard/generic F150 forums get much more traffic than the "specialty" forums...especially here on FTE. Proof of that can be seen here within the F150-related forums. The 2009-10 F150 forum (opened in 2007?) has almost as many posts as this Lightning forum which was opened back in 1999(?).
Reading between the lines, he is going to get rid of the original Lightning motor configuration in order to go with a "large crate motor". And, even though the Lightning came with a supercharged motor, it still shared some drivetrain components & electronics with the rest of the F150 line-up. That places his query about "issues with the computer, tranny mounting, engine mounts" more into the general F150 conversation arena.
Just my thought process....(your mileage may vary )
__________________
Semper Fi
Tags
2002 , 351 , block , blocks , built , computer , crate , f150 , ford , forum , junk , lightnin , lightning , long , motors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
