E350 Second Battery - No Charge - Ford Truck Enthusiasts Forums
Old 08-05-2009, 02:22 PM
Alphabitch Alphabitch is offline
Alphabitch is starting off with a positive reputation.
Unhappy E350 Second Battery - No Charge
2000 E350 V10 - The auxiliary battery charges all the interior lights, among other things... Well, they've dimmed out over the course of 2-3 days and now the vehicle is completely dark inside. Battery seems fine, but must not be charging (at all).
Ideas anyone? I am hoping to find some sort of auxiliary battery charging system diagram or something showing where the relays and such are, so I can get in there and find the fix.
I have no clue where to start... ANY help would be amazing. Thanks!
Old 08-05-2009, 07:13 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
All I can find at autozone is the single battery system with the single alternator shown here.
http://www.autozone.com/autozone/rep...All%20Gasoline)
If you look at the diagram, there is a "battery junction box". This is the underhood fuse box, and if you notice, they have a large fuse in there for the regular battery. I would check and see if you have another large fuse in there for the aux battery. And also follow the aux battery wiring and look for any open fusible links.
If I get time, I have the factory manual for your model at home, and I will see if they have the aux battery diagrams.
Old 08-06-2009, 10:22 AM
This is definitely a good jumping off point. Thank you so much.
I read something yesterday that there is an "Aux Battery Relay located on the base of the Aux Battery tray." When I get home this evening I'm going to have to pull it into my barn (where I have a pit) and check that out too.
Beforehand though, your suggestion allows me to go out to the parking lot here at work during business hours and if the 60A fuse is toasted, get it changed out before having to disassemble that "amazingly inconvenient" second battery housing.
With fingers crossed, I will give it a look-see and let you know what I find.
Please let me know if you find more info out... The web has been pretty dry on info regarding this.
Thanks Again!
Old 08-07-2009, 01:46 PM
Franklin2's Avatar
I had trouble finding the aux battery on my DVD at home. When I finally did find it, I then knew where to look on the autozone site. Here's a link. If you keep hunting around in the power distribution diagrams, you may find more.
http://www.autozone.com/autozone/rep...e%2005%20(2000)
Old 08-07-2009, 02:39 PM
Awesome! Thanks again so much. Yesterday I discerned that the 60A fuse was fine as were any dash-side fuses... This gives me exactly the "fuel" necessary to go further.
I'm pulling it ALL apart this weekend. I WILL find it dammit!!!!
Hopefully, I will be able to post the resolution to it all come Monday!
Thank you, thank you, thank you!
Old 08-10-2009, 09:28 AM
OK, my weekend endeavors were fruitless. After tracing the lines and disassembling the second battery housing (PIYA!!!) I at least know that the second battery is now completely dead. But I do not know how it happened or what drained it. (it was only a year old - from the dealership)
I did discover that what ever it was, when I put our battery tester / charger on the unit to figure it out... There was a loud pop and sizzle followed by a lovely plumb of smoke from my, now DEAD, battery charger (RIP).
Completely baffled and no closer to figuring it out, I gave up until I can replace the battery and try again.
Solenoid? Relay? I dunno. Does anyone know how to test those buggers?
Sigh.............
Gain the power to broaden your travel horizons Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 07-10-2015 12:47 PM
Charging towed vehicle battery oldtrojan66 1999 to 2016 Super Duty 10 05-03-2014 01:23 PM
Aux. Battery Charge Relay WilleyB 1968-2013 Full Size Vans 4 11-28-2012 04:02 AM
1993 Econoline trailer charge wire RedLance Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 1 04-24-2011 01:02 AM
Auxiliary Battery Charge Relay gectwo Electrical Systems/Wiring 2 09-23-2009 11:12 AM
Tags
2001, 250, auxiliary, batteries, battery, box, charge, diesel, e350, ford, fusible, junction, links, location, tray
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
