Replacing u-joints 1994 F250 ?
The rear u-joint on my 2WD 1994 F250 2WD IDI is worn ( symptom getting vibration at 50-60 mph under load) . The front universal joint I will replace both front and rear u-joints. I will use a vise or clamp with a socket to press them in the driveshaft yoke where needed . I notice a fair amount of sideways play (but no seal leakage) in tail shaft of the transmission . I am wondering if the tailshaft bearing is bad too.
Any comments or recommendations are appreciated.
1984F2506.9
12-04-2014 11:32 PM
Mustangking1
07-25-2013 05:01 PM
guitars2
11-05-2001 09:29 PM
