2006 electric 4x4 engagement problem
I am having problems with the electric actuation of my transfer case on my 2006 F-250. I can move the dash mounted switch and nothing happens at the actuator. I have replaced the switch, removed the actuator from the t-case to look at it and still no movement. Is there a fuse, relay or computer reset I need to do to reengage the 4x4 actuation?
Any help would be greatly appriciated.
There are two shift relays under the hood near the power distribution box, but they may be somewhere else on the 2006.
If the switch on the servo assembly is no good, the electronics won't know what gear the transfer case is in and won't even try to shift. Check all the connections on that switch.
