Manual locking hub question!
Hey, im from the 1987 to 1996 Forums.
I did ball joints on my 88 F-150 with manual locking hubs the other day. It was the first time I took apart a 4x4 hub and I messed up...I took the lock apart on the one side. Is it ok to drive without it in the axle? I want to pull it out and take it somewhere to have it put back together, cause I dont know how to put that spring back in the right way. It doesnt lock right now and id like to have that option available when it snows... Im a southern boy and snow isnt my thing... Heh.
Thanks in advance!!!
Well, I have a Haynes manual and ill tell you right now, from the day I got it I thought it sucked! It doesnt elaborate things which is why I accidentally took apart the lock hub. I was poking around but I finally found out what I needed to do. I dont really want to pull the other side apart. I know how it goes together, just not how to put it together. If that makes sense. Is it ok to drive without these locks in the hub????
I only took apart the part that engages the 4WD. I have some pics in my 'garage' section of it.
And.. I painted my grill green because I got bored..............
He painted his grille green because it kicks ***.
Why not? :P
As long as all the lock nuts are still in there.. I don't see anything bad happening, but then again, what else would be missing? A spring? Some doodad? I'm not completely sure what you are missing out of your hub? And why you can't just put it back in. If you've taken any of the nuts off, I would not drive like that, you'll probably lose a tire. Crack open the other side and take a look how its supposed to look. If you understand, put them both back together.
Why not? :P
Why not? :P
Why not? :P
mr.fordneck
12-21-2013 09:27 AM
Volvo92906
05-10-2011 12:28 PM
