Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #61 (permalink)
Old 11-06-2009, 09:56 AM
danshula danshula is offline
2006 Ford F-350
danshula is starting off with a positive reputation.
EGR and Professional talk
I think that the main problem we the "newbie" have is to understand the professional language you the experts use.
I can see that many of you really know and understand the subject and I respect it very much but for me it is like listening to 2 doctors speaking.
If one says "do the ERG" , does it mean -replace ERG,Upgrade ERG,Clean ERG or what?
I RV already 9 years and know a lot about 5W ,and RVing, when I answer a post on RV forum I try to spell it out for any one that asked a question,then I read my post and look at it with a newbie eyes to see if it is understandable.
So PLEASE explain to me what to do with my stock ERG.
Thank you.
__________________
F-350,2006,6.0 lT,EC,2WD,LB,3.73 Ratio,SRW.
pulling a 2006 5w Cruiser from Crossroads.
  #62 (permalink)
Old 11-06-2009, 11:24 PM
hangon2me hangon2me is offline
hangon2me is starting off with a positive reputation.
Do the full EGR delete for sure!!
Your truck and your wallet will thank you.
__________________
2005 F350 4X4 King Ranch long bed
BF Goodrich KM2 Mud-terrain 35/12.50/R18, Bush-wacker's, level kit, ARP Studs, Accufab intake Elbow, SCT X3 with Spartin Tunes,Full EGR Delete, Pyrometer in a single pod,Full 4" Magnaflow turbo back exhaust with 5" tip w/ modified Cat to 4" inlet/outlet, Zoodad, CCV Re-Route
  #63 (permalink)
Old 11-07-2009, 12:13 AM
2006 Ford F-350
ERG
If I do it now will my warranty still be intake?
__________________
  #64 (permalink)
Old 11-07-2009, 12:24 AM
cheezit cheezit is online now
cheezit is gaining momentum as a positive member of FTE.
the warrenty issue is has so many varibles there is noone that can awnser that. It depends on what goes wrong with the truck. But I would say that an egr delete will cause you some issues with warrenty. 2006 model year truck would require the use of a programer to disable the egr vlave. The use of a programer and a modified egr system will get you.
Now Im sure someone will say that Ford has to prove that the item caused the failer... thats only partly true. All they have to prove is it was a contrubiting factor not the sole cause.
I have had this fight so many times with customers and in the end we just expain how unhappy the epa will be and offer to provide the vin and owner info to them.
And yes you can fight it and you may be able to win but ford has a lot of laywers
  #65 (permalink)
Old 11-07-2009, 01:23 PM
flamebuster flamebuster is offline
flamebuster is gaining momentum as a positive member of FTE.
Thank you.
Very good point, but most of the guys here will give more in depth information when asked.Plus a lot of the answers can be found by spending some time reading the first posts in each forum this has lots of information most newbies are looking for and there is always the search engine on this site. I have spent hours and hours reading information here for the just in case, trouble is I can't remember it all.. ha ha.Check out the 6.0 bible it has pictures and location descriptions very useful for getting to know your truck.
I personally unhooked my egr (exhaust gas recirculation valve) for about 3 weeks and found my motor would surge at idle and while cruising at hiway speeds by 50 to 100 rpm's. I hooked it back up and I am satisfied with how the truck runs stock.
With that said I am still contemplating a spartan tune just for extra power and to boost my ego, but not untill I install gauges to get some base figures,to compare to the changes of the tuner.Doug.
__________________
DOUG
2004 F-350 Super Duty Crew King Ranch . 6.0 psd...coolant, filter, slotted and drilled rotors,kitty ran away, air bags,leveling kit, progigy,piaa lights,
2003 EXP; All stock Wifes ride!!!
2006 2500HD gmc.All stock work trk.
  #66 (permalink)
Old 11-07-2009, 02:19 PM
If you want the warranty, I installed the sneaky turbo up-pipe with the blocker plate form elite diesel. I had no issues with any warranty issues ever. Made with genuine Ford parts with the up-scoop missing. Check this out 6.0L EGR Components
Now I modified the factory up-pipe and did a full delete.
Now my truck's fan rarely comes on, before it ran all the time in the summer (always had a heating issue).
EGT's are lower, MPG increased and fun to drive went threw the roof.
__________________
  #67 (permalink)
Old 11-08-2009, 08:41 AM
kidoo kidoo is offline
kidoo is starting off with a positive reputation.
Can you just kleen the Egr once in a while? How long does it take? Is there some people that never had a problem with the EGR.
My truck is warranty for another 2 years, should I buy an extended warranty to cover that )*&%/)_ egr?
__________________
Black and chrome beauty, F350 Lariat, crew cab diesel, 8 foot box, 2006, 4x4, Fun toys, Kodiak Camper, Zodiac boat, Polaris ATV, Scandic sleed. Life is short, take it all.
  #68 (permalink)
Old 11-08-2009, 06:43 PM
vloney vloney is offline
vloney has a very good reputation on FTE. vloney has a very good reputation on FTE. vloney has a very good reputation on FTE. vloney has a very good reputation on FTE.
Lets say just for the sake of arguement, that the egr system wont cause any problems when working properly. If theres an issue that causes the cooler and valve to fail, won't just deleting the system fix the symptom and not repair the problem?
__________________
ase master tech--fmc master tech81 f150--300 4x4
  #69 (permalink)
Old 11-08-2009, 07:32 PM
dcoy dcoy is offline
dcoy is starting off with a positive reputation.
i would say deleting the egr takes care of the problem
  #70 (permalink)
Old 11-08-2009, 08:11 PM
sorry dcoy but that will only fix what is currently wrong. It will do nothing to cure the problem that caused the failer. failer to address the issue will result in continued puking out of the degas and an engine that runs to hot.
also deleteing any part will require a change in programing to make the truck operate correctly.
the bigist cause is going to be lack of cooling system maintance. Theres only one thing that will cure that and thats going to be owner education.
  #71 (permalink)
Old 11-08-2009, 08:33 PM
locomike's Avatar
locomike locomike is offline
locomike is starting off with a positive reputation.
I love this debate but for those of you "IN NEED NOW" do a full EGR Valve and EGR Cooler delete with SCT custom tune from Eric.
To put it in perspective.... The masterr ford tech is obviously really informed and more experienced than those of us who don't do this for a living. SO IS MY DOCTOR !!! If you have a cancer you have it removed. You don't like it, your Dr. doesn't like it but it is the lesser of two evils.
The EGR cooler is a FORD CANCER. The engineers didn't just do it to screw us, the regulations by our brilliant government. CUT THE EGR/CANCER out !!!
If you do decide to be proactive, do it right. Blocking the EGR leaves the cooler in the loop. Do a full EGR cooler delete. I personally chose one of the more expensive and went with an entire EGR delete manifold.
Now.... "Back to the experts" who know all the technicals. I am just a dumb engineer who enjoys working on my own truck. But, all the garbage they made me learn left a little room for my common sense
  #72 (permalink)
Old 11-08-2009, 08:43 PM
i am just a back yard mechanic and it makes perfectly good sense to me to delete the egr putting dirty air from the exhaust at 900 plus degrees f makes no sense it goes against trying to cool the air your forcing in with the turbo also that hot exhaust running through the egr cooler makes no sense you would need more radiator to keep this silly confiuration cooled
  #73 (permalink)
Old 11-08-2009, 08:46 PM
Quote:
well I wount argue that point.
noone has said not to delete the egr system. I will say that as an engineer you should be able to figure out a little bit about what is causing the concern. after all Im not the collage grad here.
Do some looking around at cooling systems and checmical dropout that happens. Once you begain to grasp that you will see and understand the biggist issues.
If you go in and all you replace or delete is the egr cooler you will have other issues and left unresolved will continue to eat away at your pocket.
There is a thread about vc9 you should read that as well. you should also be looking at the relationship of eot vs ect and it will all come together.
  #74 (permalink)
Old 11-08-2009, 08:57 PM
help us out then becouse if this mod does not help your ect and eot whats the problem behind this
  #75 (permalink)
Old 11-08-2009, 09:02 PM
locomike's Avatar
I will take your advice and try and become more informed. Thanks because I will take all the good info I have time to research.
When I don't know all the details I revert to common sense.
Being an 'college grad' only means you have the capacity to learn, not that you know everything LOL. Most politicians are 'college grads' and look where they have gotten us !!!!
This is one of the best threads I have seen. Lots of expert info and lots of head scratching so... THANKS
Sorry, just wanted to give my respect the debate.
Tags
03 , 2003 , 60 , 60l , adjust , delete , disabled , egr , f150 , f250 , ford , powerstroke , valve , vaules , warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
