Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 11-02-2009, 11:30 AM
bkvanbek bkvanbek is online now
bkvanbek is starting off with a positive reputation.
This info is over-my-head, I think I speak for quite a few when I say we want the bottom line so we can decide what to do. What are the opinions out there?
__________________
2003 F 350 XLT Sport 4x4 6.0L Diesel
Bank's Big Hoss with PDA
  #47 (permalink)
Old 11-02-2009, 02:56 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke MoyockPowerstroke is offline
MoyockPowerstroke is gaining momentum as a positive member of FTE.
Quote:
Here's what I plan to do after careful thought and research...#1) gauges (either Edge Insight -multiple PIDs one device-keeps grab handle or multiple analogue electronic sensor- traditional but more costly and more work). #2) SCT tuner...best tuner for our engine and especially the Torqueshift tranny...most likely will add the custom tunes that will eliminate EGR values...ultimately no CEL...you have an '03, so this shouldn't be a concern for you, but I'd get it that way anyway. and...#3 EGR delete...either a kit and DIY or get a competent local diesel repair shop to put either their kit in or your aftermarket kit...most local diesel shops know about deleting the EGR cooler, so sometimes you make out better having them perform the delete with their kit. One local shop by me uses Elite Diesel's kit and performs the delete for $500.
__________________
Real Trucks Don't have Spark-Plugs '05 6.0L, 84k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto, Coolant bypass, ZooDad, HighIdleMod, BullyDog 4" TB 4"DP (BullyDog ate Kitty), SCT SF3 Perf Strat.w/Edge Insight for gauges, 24" Wipers, '08 Diff Cover, Upfitters, Skyjacker/Russell brakes lines, M/C Max 100 BXT-65-850s, Mobil1 Syn 5W-40, Wagner ThermoQuiet's, Stanadyne Perf Add & FPPF Lubricity+Power Add., Prodigy Brake Controller, Nitrogen filled Bridgestone Dueller A/T Revo's, Satellite radio, Sun-visor.
  #48 (permalink)
Old 11-02-2009, 08:50 PM
cheezit cheezit is offline
cheezit is gaining momentum as a positive member of FTE.
this is gonna be fun...
Iat: will not change from its readings as that is part of the MAF
Iat2: wich is in the intake will not show a fluctuation the way it shoud as this isthe monitor for egr flow. but it will read the correct temp.
Map will read the correct intake pressure... the reason is if this is wrong boost value is also wrong. the calc the pcm uses for boost is.... MAP - BARO = BOOST.
now for for the egr valve both egrv,egrdc#,egrg,egrtp.
egrtp will not change as thats just a throttle plate and only on 03-04my
egrdc# will be incorrect if the valve and set to default
egrv will read correctly 5volts (a value that will set the mil with out of test range)
egrg egr gauge pressure is a calc value from I THINK it equals egr - baro and it would also read incorrectly
Eot will also read correctly
ebp will also read correctly as this is just a pressure pid.
so in short any valve that still reads correcltly will be what is really there to check for system operation and it will fail and set the cel.
now what we didnt cover is what I find to be a little interesting...
the egr is there to reduce NOx wich happens at temps above 1500 degrees f.
so that should also equal an incress in cyclinder head pressures. as we should all know that when temp incresses pressure will also incress.
  #49 (permalink)
Old 11-03-2009, 10:55 AM
clinter36 clinter36 is offline
clinter36 is starting off with a positive reputation.
Trying to follow along - there is a lot of great information here.
So far it is apparent that deleting the EGR is going to throw off the computers inputs and possibly calibrations. Whether, it can compensate using other input values or not I think remains to be answered..?
But here is my question...What about simply disconnecting the EGR - or disconnecting in conjunction with the delete kit (I realize there will be codes) - the reason being that the open circuit at least lets the computer know that the EGR is not working and it can go about its thing using other values? (I have had mine disconnected for some time including heavy towing with no noticeably bad results.)
Clint
  #50 (permalink)
Old 11-03-2009, 07:51 PM
it has been proven to work. the thing at hand is what is the final result of and the long term effects. also to discuss the negitive side of just deleting stuffs and never fixing the root of the problems
  #51 (permalink)
Old 11-03-2009, 07:59 PM
Cheezit,
Whaaaaat??
__________________
  #52 (permalink)
Old 11-04-2009, 02:05 PM
danshula danshula is offline
2006 Ford F-350
danshula is starting off with a positive reputation.
EGR
As I posted already I am new to 6.0LT and will be getting my F-350,2006,Auto,EC,2WD in 3 weeks.
Mean time I started reading to get familiar with it.
It is completely stock and I will be using it only to pull my 5W in summers (plus some side trips)
I have no intentions to play with it just do ALL the necessary maintenance and do things to prevent future damage.
I was advised to add Oil By pass,Coolant filter and Gauges(which I will do when I get the truck) but have no idea what to do about EGR it might be because I do not understand the mechanical terms and abbreviation.
Please advise on the matter and add your thoughts on what gauges are need to install (please in "normal" words).
Thank you.
__________________
F-350,2006,6.0 lT,EC,2WD,LB,3.73 Ratio,SRW.
pulling a 2006 5w Cruiser from Crossroads.
  #53 (permalink)
Old 11-04-2009, 11:53 PM
da-bees da-bees is online now
da-bees is starting off with a positive reputation.
Thank you.
Hello Dan,right up front I don't know 1% as much as the gentalmen having the discussion. I will however offer you a few tips I have picked up along the way. Oil tempature(eot) and coolant temature(ect),fuel pressure are the 3 must have guages and other guages are good to have because origional in dash guages are not very accruate. The exhust gas recirculation(egr)system is the#1 subject of debate regarding our trucks,therfore there is no right or wrong answer what to do about it. Install the bypass filters(no one feels they hurt,and most think they help)ditto for guages. Do searchs and read thru tech files on the subject then decide what's in your best interest. Meanwhile this discussion is by some very talaented and forward thinking indivuals about the subject far more advanced than I can talk about. Best of luck with your new diesel. Keep reading and enjoy,it will all come togather for you. Hey fellers,thank you for taking this egr thing out of the box. Great stuff even though it's making my whiskers grow faster trying to keep up.
  #54 (permalink)
Old 11-05-2009, 06:59 AM
scameron scameron is offline
scameron is starting off with a positive reputation.
i don't know how many times i have read about the EGR deletes. my situation, cooler cracked 4 months after i did a coolant filter. i didn't have the money to replace so i made my own delete (works great by the way). immediate change in boost. the truck would only boost to 22 to 23 pounds. purchased a tuner from ID with the delete programs and no change in boost. racked my brain for many months trying to figure out what is wrong. finally said to hell with it. truck runs great. did notice i needed to replace my boots. maybe they are leaking. also, at wide out throttle my boost gauge will bouce sometimes. gauge is plumbed into the intake elbow. my truck is a 2005.
  #55 (permalink)
Old 11-05-2009, 10:26 AM
2006 Ford F-350
ERG
Quote:
Thank you da-bees for your post,but bottom line a do not know what to do regarding ERG at this point...
Please spell it out for me (what to buy and how to install).
__________________
  #56 (permalink)
Old 11-05-2009, 06:12 PM
Dido what Dan said. What should we do? In my case my orange coolant hose, to EGR cooler, leaks.
__________________
  #57 (permalink)
Old 11-05-2009, 09:05 PM
kidoo kidoo is offline
kidoo is starting off with a positive reputation.
In regards to coolant, what type do you use, how much do you need? Cost? If you replace the coolant more frequently, would it reduce the risk of rust and many othee problems?
__________________
Black and chrome beauty, F350 Lariat, crew cab diesel, 8 foot box, 2006, 4x4, Fun toys, Kodiak Camper, Zodiac boat, Polaris ATV, Scandic sleed. Life is short, take it all.
  #58 (permalink)
Old 11-05-2009, 09:20 PM
so far as the orange hose leaking thats an easy fix. the part is like $35 and sold by itself. there is no need to remove anything but the tube itself to change it. ford pays us 1.0 for the job. Cp time is between 1.5 and 2 hours plus coolant.
and what type of coolant.... motorcraft gold.
not only changing the coolant but flushing the cooling system is the issue. you can only get so much of the silica (what is often mistaken as casting sand) by a simple drain and fill. also the use of flushing with vc 9 (iron remover) is also helpfull in preventing the chemical fallout wich porduces the silica.
  #59 (permalink)
Old 11-05-2009, 09:24 PM
But should I replace the orange hose, or should I delete the EGR?
__________________
  #60 (permalink)
Old 11-05-2009, 09:27 PM
I would just install the 35 dollar part. its far cheeper then the cooler delete. there is an updated hose thats been around for a few years now and is doing much better then the orange one.
that little tube by the way is just the coolant supply. if the cooler fails you will see lots of white smoke out the tail pipe and your heater wont work.
Tags
03 , 2003 , 60 , 60l , adjust , delete , disabled , egr , f150 , f250 , ford , powerstroke , valve , vaules , warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
