Snap Ring Pliers
Snap Ring Pliers
I have a 2004 SD and I broke a set of craftsman 8" snap ring pliers on the stub axle snap ring. I need to know how big and what brand you guys have used on that snap ring. I would like to buy the tool once and be done with it. This is a great website for information. Thanks
As with any tool you want to last a lifetime (without needing to use a warranty) you'll have to shell out some money. Aldridgec mentioned MAC, which is a great tool brand. You might also want to look at a Snap-On or a Cornwell pair on ebay. Any one of those 3 should work for the rest of your life.
I bought snap on snap ring pliers, they are adjustable for inside/outside ring. They are very beefy, around 30 bucks. They dwarf the craftsman ones that I have, but are still a nice manageable size, and way better made. If you break them, your doing something way wrong. SRPC 9000A is the model #... you can buy them on snap on.com Just make sure the tips aren't to big.
JD
JD
JD
JD
can you spin the snap ring in the groove?
If the answer is no, give it a few taps with a brass punch and a heavy hammer to free it up.
If there is extra pressure on the snap ring for some reason, it'll take a lot more force to pop out of the groove. It should be a rather painless removal.
I was thinking about that last night TexasRebel. Maybe the axle had the snap ring bound up, or corrosion had the snap ring stuck to the axle. Next time I will hit it with WD40 and pry the axle out from behind to give the snap ring some play, then make sure I can spin it in the groove before trying to take it off. Thanks again
