Snap Ring Pliers - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Snap Ring Pliers
Old 08-04-2009, 08:33 PM
wideglidewoody00 wideglidewoody00 is offline
wideglidewoody00 is starting off with a positive reputation.
Snap Ring Pliers
I have a 2004 SD and I broke a set of craftsman 8" snap ring pliers on the stub axle snap ring. I need to know how big and what brand you guys have used on that snap ring. I would like to buy the tool once and be done with it. This is a great website for information. Thanks
Old 08-05-2009, 02:00 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
On the little snap ring inside the hub? I have a set of Mac ones that I use, but there shouldn't be anything that substantial about removing it.
Old 08-05-2009, 03:12 PM
Yes its the little snap ring inside front hub on the end of the stub axle. The craftsman pliers bit the dust so I know they have to be heavier than that pair. I will have to see if I can find a pair in the Mac brand. Thanks.
Old 08-05-2009, 04:24 PM
brian42's Avatar
brian42 brian42 is online now
brian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to behold
I would just make sure that the point is strong enough to withstand the force required to pry the ring open to get it around the axle splines. I'm a Craftsman guy, but I thing I used a Snap-on or Matco set of pliers on it that I borrowed.
MikeMcCasland's Avatar
MikeMcCasland MikeMcCasland is offline
MikeMcCasland is gaining momentum as a positive member of FTE.
As with any tool you want to last a lifetime (without needing to use a warranty) you'll have to shell out some money. Aldridgec mentioned MAC, which is a great tool brand. You might also want to look at a Snap-On or a Cornwell pair on ebay. Any one of those 3 should work for the rest of your life.
Old 08-05-2009, 04:32 PM
What looks to be the heaviest set I've found so far are the OTC4513. Description says for heavy equipment use. I'll check out snap on and cornwell. Thank
Old 08-05-2009, 04:36 PM
RIF350guy RIF350guy is offline
RIF350guy is starting off with a positive reputation.
If you only want to buy one pair, I would look into buying a pair that is a little longer than most.... it wont hurt to have any if you buy a newer truck you'll need the length.
Old 08-05-2009, 04:45 PM
I have 4 average size pair but that is a beefy snap ring on the end of that axle. The craftsman I broke had 8" handles so I know to go bigger than that, maybe 16".
Old 08-05-2009, 05:05 PM
I bought snap on snap ring pliers, they are adjustable for inside/outside ring. They are very beefy, around 30 bucks. They dwarf the craftsman ones that I have, but are still a nice manageable size, and way better made. If you break them, your doing something way wrong. SRPC 9000A is the model #... you can buy them on snap on.com Just make sure the tips aren't to big.
JD
JD
Old 08-05-2009, 09:43 PM
Thanks all you guys for your input. I just ordered the SRPC9000A from snapon.com. RIF350guy said they were pretty strong so I will give them a shot.
Old 08-05-2009, 11:11 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
I bought a $4 pair of 7" ones made in China from eBay (free shipping) and did both sides off and on. I think you had a bad plier.
Old 08-05-2009, 11:18 PM
Monster-4's Avatar
Monster-4 Monster-4 is online now
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
Channel Lock also makes a really nice one as well. I bought one after fighting for years with my cheapo one. That cheapo one however did make it throught taking out the snap rings on the axles. Twice.
Old 08-06-2009, 12:40 AM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
can you spin the snap ring in the groove?
If the answer is no, give it a few taps with a brass punch and a heavy hammer to free it up.
If there is extra pressure on the snap ring for some reason, it'll take a lot more force to pop out of the groove. It should be a rather painless removal.
Old 08-06-2009, 10:05 AM
I was thinking about that last night TexasRebel. Maybe the axle had the snap ring bound up, or corrosion had the snap ring stuck to the axle. Next time I will hit it with WD40 and pry the axle out from behind to give the snap ring some play, then make sure I can spin it in the groove before trying to take it off. Thanks again
What size snap ring plier for front 4x4 hub? VORTMAX_99 1999 to 2016 Super Duty 30 11-26-2016 01:16 PM
05 f250 front axle problem donp68 1999 to 2016 Super Duty 5 11-26-2015 12:17 PM
Snap Ring inside the front Hub 2005 wy4525 6.0L Power Stroke Diesel 5 06-11-2015 03:35 PM
05 F 250 front axle snap ring tool mtnxtreme 1999 to 2016 Super Duty 10 08-26-2014 01:27 PM
Snap ring removal??? kelsey344 6.0L Power Stroke Diesel 5 06-24-2012 09:00 PM
Tags
9000a, buying, cornwell, craftsman, ford, good, pair, pliers, removal, ring, snap, snapon, srpc, stuck, tool, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
