Trying to juggle a beverage while driving my 80 manual flareside sucked. Since I needed to replace my seat anyway, I decided to add a custom cupholder to it. It was super easy to do and it works awesomely.
Here's how:
First get a seat from the junkyard with a flipdown armrest (curious dog optional):
Get a little coping saw, or some cutters or something that will cut ABS plastic and some sandpaper:
Pick up a simple cupholder. This one was $3 at walmart.
Cut off how ever much of the cupholder tray thing you dont want. If you have room and/or want to, you could keep the whole thing. I just wanted the cupholder.
If you care about the open hole you'll have at the back (I did), get a small sheet of ABS plastic ($1 from Tap Plastics), trace the height of the hole, and cut a rectangular backer piece.
Glue the piece of sheet to the back of the cupholder with ABS cement (got this at home depot).
Add a little bondo and sand it down to make a smooth transition from your cupholder piece to your patch piece.
Paint the whole thing. I like this paint for textured plastic.
Flip down your arm rest, place the cupholder where you want it and trace around it with chalk.
Draw another line about 1/2" or so inside the tracing. This will be your cut line and will help make a snug fit for the cupholder inside the foam. Cut the fabric into flaps. KEEP THE FLAPS as you will glue them inside the hole to make a more finished look. Do not cut the flaps off.
Flip the fabric flaps back and dig out the foam. (In my pic, the left and right flaps are too short to fold out of the way so i had to dig under them. Not hard though.
When the foam is clear from the hole, use spray adhesive to glue the fabric flaps inside to the walls of the cut foam.
When the glue dries, push the new cupolder into the foam. You can glue it in there if you like but I found that the fit was snug enough that i didnt need to.
That's it! It flips up and hides away when not in use. Super handy!
__________________
Em
1980 F100 Custom Flareside; 2wd; Manual; 300 I6
I see every truck as a potential parts donor.
__________________
1981 Ford f-100 302 windsor/C6/3.25/9.0 rear
Bass, walleye, catfish, and trout, im tellin you now you'd better look out! You were safe in the lakes when i was home wishin. But be on your guard cause im goin fishin!
cool, guys, thanks! i hope it's a useful solution to some folks. it makes me happy every time i get in my truck and have someplace to put my coke or coffee.
__________________
Em
