2000 F250 7.3l cheap mods - Ford Truck Enthusiasts Forums
Old 08-04-2009, 07:05 AM
Mike454 Mike454 is offline
Mike454 is starting off with a positive reputation.
Question 2000 F250 7.3l cheap mods
Hey all again,
I just did the '6637' that a lot of people have done to their trucks, just need to get a cover now... Anywho, I'm needing exhaust, I have been looking at the cheap MBRP 4in turbo back? Any good? I dont know you guys are the pros... I have about a $400 budget, ( I know I'm a tight a**) I might be getting a tony wildman chip if that helps, just need something for the truck to exhale better, doesnt need to be fancy at all...
Thanks a lot
Mike
And then any advice on gauges? I've heard analog are better...Any good ones you guys have had good luck with? Thanks again
Old 08-04-2009, 07:18 AM
RedBoat's Avatar
RedBoat RedBoat is offline
Rather Be Floatin
RedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to behold
CHEAP MODS!!
Old 08-04-2009, 07:22 AM
indyF-350psd's Avatar
indyF-350psd indyF-350psd is offline
you can't fix stupid!
indyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to behold
a 4" exhaust will work well. you could save a couple bucks by getting the aluminized version then protect it by coating the outside with some high temp paint. i think i got my 4" stainless silverline system from dustys diesel with the muffler delete pipe for 450. you might want to check and see what riffraff can do for you as well.....
Old 08-04-2009, 08:08 AM
Joe_914's Avatar
Joe_914 Joe_914 is offline
Joe_914 is gaining momentum as a positive member of FTE.
I am getting the bug to fuss around with my truck as well.
I know 4 weeks ago when I bought it I said I was not goig to do anything to it.
How loud will it be if i just take off the stock muffler and run 3 1/2" pipe out the side infront of rear wheel. Will it reduce the EGT? make any more power, or anything at all except noise.
Old 08-04-2009, 09:01 AM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
MBRP, MKO, and Silverline all make good exhausts, among others. I think Clay (Riffraff Performance) has a deal going right now on a 4" aluminized system for right around what you are wanting to spend.
Old 08-04-2009, 09:23 AM
CampSpringsJohn's Avatar
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
Anything you do to free up the exhaust will lower egt's. As for loud, the closer you put the end of the pipe to the cab, the louder it will be inside the cab. Only you can answer the question about how loud it is and if you can tolerate it.
Power increase will be slight. Opening the intake and exhaust will have very little affect on power. Yes, some increase, but not much. Most of us hardly notice it. What those modifications do is help set you up to install a chip that will take advantage of those mods. While you certainly can install a chip on a stock intake and exhaust truck, it will be severely limited because of the restrictions in the intake and more importantly, the exhaust.
Old 08-04-2009, 11:10 PM
Well I put a 3.5in pipe in place of the muffler tonight and she sounds nice to me, hardly any cab noise at all...This next question will be dumb, please forgive me as I am new to the powerstroke world! My truck is stock other than my goofy 6637 intake and straight pipe, I got 113,00 miles on it, and was wondering how much smoke is normal? Just cruising up a hill with cruise on I notice smoke in the headlights behind me, not a lot, but you get the idea... Just curious if I need to look into an injector tune up...
Thanks for bearing with me!
Mike
Old 08-04-2009, 11:58 PM
Forgive my manors, but a WELCOME TO FTE is in order here!
OK, As for smoke, I wouldn't worry about it. Injector issues are usually more noticeable by a rough idle, or worse yet a dead miss. Injector O-rings are very noticeable at start up with a bunch of white/blue smoke that usually fades as the engine warms up.
It's a diesel, she's suppose to smoke a little.
Old 08-05-2009, 04:30 PM
Fully_Loaded's Avatar
Fully_Loaded Fully_Loaded is offline
Fully_Loaded is gaining momentum as a positive member of FTE.Fully_Loaded is gaining momentum as a positive member of FTE.
It is like a 2-stroke, "If She's Smoking She's Lubin" On a diesel "If She's Smoking She's making power" LOL
Old 08-06-2009, 12:42 AM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
I personally went with the supporting mods route.
Stainless high pressure crossover (HPX)
4" exhaust (ebay is your friend if you want cheap..I paid 260shipped for aluminized)
New filters, oil, trans, and air
Coolant bypass filter
Ill be doing many mods to my truck now, turbo got trashed so the upgrades and fixin begins.
Old 08-06-2009, 08:22 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Mike
If you are getting smoke on stock tune, straight pipe exhaust and 6637, then you are not getting all the air that you are supposed to be getting. Period.
If you want to improve things, start looking for exhaust leaks at the up-pipes, broken tube that goes to the exhaust pressure sensor.
I'm pretty sure you are going to find some black streaks.
Get all that fixed, then adjust the wastegate valve so it won't begin to open until you reach 10-12 psi.
No more smoke and a lot better running engine.
Old 08-06-2009, 11:06 AM
DieselBeast01's Avatar
DieselBeast01 DieselBeast01 is offline
DieselBeast01 is gaining momentum as a positive member of FTE.
Yes if you want cheap, ebay is your best friend. I only paid $350 for my MKO 5inch system.
Old 08-06-2009, 02:03 PM
BadDogPSD's Avatar
BadDogPSD BadDogPSD is offline
BadDogPSD is gaining momentum as a positive member of FTE.BadDogPSD is gaining momentum as a positive member of FTE.
Hey all again,
Thanks a lot
Mike
Check with DSTRBD for your exhaust, he had killer deal on MBRP stainless
a while back.
Ford CS refuses to escalate what would you do? Long read ford390gashog 2009 - 2014 F150 11 09-01-2016 11:08 AM
2011 5.0 Spark Plug Change - Tips roebedo 2009 - 2014 F150 8 03-09-2016 06:50 AM
shaking while braking mtondreo 1997-2006 Expedition & Navigator 15 10-21-2009 04:55 PM
91 F150 lift kit. 4 or 6 inch fordman16b Brakes, Steering, Suspension, Tires, & Wheels 2 07-21-2005 01:12 PM
Door Latch Questions... Mike in SC Bronco II 7 07-20-2004 03:45 PM
Tags
1999, 2000, 2001, 2003, 73, 73l, cheap, diesel, f250, ford, injectors, modifications, mods, power, psd, tranny, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
