*HELP* 1998 F-150 4x4 4.6 v8 Transmission Question!!!
I have a Short-Bed Single Cab 1998 F-150 4x4 4.6 v8 with ~230,000 miles on it. I recently blew up the my 4R70W transmission (Which is what kind of transmission i think i have). I plan on buyin a new transmission, but it's a 4R70W AODE. I dont know ANYTHING about vehicles.
My question is: Do i have a AOD or AODE transmission? I have overdrive with the push button on the shifter if that helps any. And how do i find out if you can't help? I looked for numbers on the transmission but had no luck. Any kind of help would be greatly appreciated.
JL
Which Transmission Model ??
I have a 98 F150 4 x 4 with a 5.4L gas engine ......which model transmission do I have ?? Where can I verify that information ? Thanks
You have to have a replacement that has all the correct speed sensing back to the Computer.
They changed as the model years progressed.
For info only, an AOD cannot be considered because it is not an electrically controlled transmission.
Some internal AODE/4R70 parts will interchange into the old AOD but the trans cannot be used in PCM controlled vehichle.
If you try a conversion using a later model, be sure the person doing it knows what to do or you will get into a hassle.
Good luck.
Good luck.
Nathan511
22
06-02-2020 11:55 AM
witdog2020
01-09-2006 07:47 AM
