Trouble code PO299 Turbo charger underboost
Old 08-03-2009, 09:18 PM
Jim83's Avatar
Jim83
Jim83 is offline
Unhappy Trouble code PO299 Turbo charger underboost
What does this mean???
i have 60000 miles on it, no real problems so far but i noticed it had less power then usual and ran my superchips scanner and this is what i found.
Trouble code PO299 which means turbocharger underboost when i look it up.
Thanks
~jim
Old 08-03-2009, 09:21 PM
jboczar's Avatar
jboczar
jboczar is offline
Can actually mean under/overboost, so many things can be cause this:
Fuel Pressure
High Pressure oil concern
Turbocharger
Exhaust Leak
Egr valve
Air intake restriction
VGT Actuator
What year truck and how many miles? Checking egr valve is always a good easy place to start. 2 8mm bolts, turn sideways, pry up on tabs.
Old 08-03-2009, 09:34 PM
Jim83's Avatar
Jim83
Jim83 is offline
justa had the egr replaced.
but i did have to change the fuelfilter today because they were so clogged up. that is prbly why it set the code off
my trck is a late 04
thanks for the quick reply
Old 08-04-2009, 12:04 AM
3000 FPS's Avatar
3000 FPS
3000 FPS is offline
In most cases where this code shows up it is because the vains in the turbo are starting to stick. Like jboczar says it can be an overboost or an under boost. Your truck is a 2004 which means there is no boost gauge. You may consider putting one in.
Old 08-04-2009, 03:40 AM
dc3655's Avatar
dc3655
dc3655 is offline
When my friend had this code pop up on his 04 Excursion last year, the dealership replaced the entire turbo. Now that you're probably out of warranty, hopefully it's something more simple and you can get away with just cleaning the veins of the turbo to save some cash.
Old 08-04-2009, 06:41 AM
bismic's Avatar
bismic
bismic is online now
Received 2,490 Likes on 1,727 Posts
If you run your fuel filters until they clog up, then you will have injector problems. No ifs, buts, or maybes. Low fuel pressure KILLS the injectors. When you have even one fuel injector operating poorly, you will get more soot generated. This can increase the chance of clogging up turbos, EGR systems, and sensors.
thaemcee2
12-13-2017 04:17 PM
eclectix
04-14-2017 02:53 PM
fellro86
Crossovers
07-23-2016 12:25 PM
Jim McGuire
03-26-2016 04:14 PM
AC94EXPLORER
12-20-2008 06:19 PM
Quick Reply: Trouble code PO299 Turbo charger underboost
