Trouble code PO299 Turbo charger underboost
What does this mean???
i have 60000 miles on it, no real problems so far but i noticed it had less power then usual and ran my superchips scanner and this is what i found.
Trouble code PO299 which means turbocharger underboost when i look it up.
Thanks
~jim
Thanks
~jim
Can actually mean under/overboost, so many things can be cause this:
Fuel Pressure
High Pressure oil concern
Turbocharger
Exhaust Leak
Egr valve
Air intake restriction
VGT Actuator
What year truck and how many miles? Checking egr valve is always a good easy place to start. 2 8mm bolts, turn sideways, pry up on tabs.
Fuel Pressure
Turbocharger
Exhaust Leak
Egr valve
VGT Actuator
If you run your fuel filters until they clog up, then you will have injector problems. No ifs, buts, or maybes. Low fuel pressure KILLS the injectors. When you have even one fuel injector operating poorly, you will get more soot generated. This can increase the chance of clogging up turbos, EGR systems, and sensors.
thaemcee2
12-13-2017 04:17 PM
Jim McGuire
03-26-2016 04:14 PM
AC94EXPLORER
12-20-2008 06:19 PM
