Trouble code PO299 Turbo charger underboost - Ford Truck Enthusiasts Forums
Old 08-03-2009, 10:18 PM
Jim83's Avatar
Jim83 Jim83 is offline
Jim83 is starting off with a positive reputation.
Unhappy Trouble code PO299 Turbo charger underboost
What does this mean???
i have 60000 miles on it, no real problems so far but i noticed it had less power then usual and ran my superchips scanner and this is what i found.
Trouble code PO299 which means turbocharger underboost when i look it up.
Thanks
~jim
Old 08-03-2009, 10:21 PM
jboczar jboczar is offline
jboczar has a good reputation on FTE.jboczar has a good reputation on FTE.
Can actually mean under/overboost, so many things can be cause this:
Fuel Pressure
High Pressure oil concern
Turbocharger
Exhaust Leak
Egr valve
Air intake restriction
VGT Actuator
What year truck and how many miles? Checking egr valve is always a good easy place to start. 2 8mm bolts, turn sideways, pry up on tabs.
Old 08-03-2009, 10:34 PM
Jim83's Avatar
justa had the egr replaced.
but i did have to change the fuelfilter today because they were so clogged up. that is prbly why it set the code off
my trck is a late 04
thanks for the quick reply
Old 08-04-2009, 01:04 AM
3000 FPS's Avatar
3000 FPS 3000 FPS is offline
3000 FPS is gaining momentum as a positive member of FTE.
In most cases where this code shows up it is because the vains in the turbo are starting to stick. Like jboczar says it can be an overboost or an under boost. Your truck is a 2004 which means there is no boost gauge. You may consider putting one in.
Old 08-04-2009, 04:40 AM
dc3655 dc3655 is offline
dc3655 is starting off with a positive reputation.
When my friend had this code pop up on his 04 Excursion last year, the dealership replaced the entire turbo. Now that you're probably out of warranty, hopefully it's something more simple and you can get away with just cleaning the veins of the turbo to save some cash.
Old 08-04-2009, 07:41 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
If you run your fuel filters until they clog up, then you will have injector problems. No ifs, buts, or maybes. Low fuel pressure KILLS the injectors. When you have even one fuel injector operating poorly, you will get more soot generated. This can increase the chance of clogging up turbos, EGR systems, and sensors.
turbo underboost cmdevildog16 6.0L Power Stroke Diesel 4 01-28-2012 10:30 PM
Wheel widening PooreBoy Washington Chapter 12 10-14-2010 08:52 AM
nylon king pin bushing 1959_f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-04-2009 02:14 AM
SuperCharged Turbo Underboost, code PO299, means what? strf12 1999 to 2016 Super Duty 3 04-29-2009 05:59 PM
Whats the best oil to run in the 6.0?? sctrooperlx 6.0L Power Stroke Diesel 92 02-13-2009 06:05 PM
Tags
2009, 299, 60, code, diesel, engine, f250, ford, po, po299, scanner, trouble, turbo, turbocharger, underboost
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
