Horsepower ratings, Interesting
Old 08-03-2009, 08:47 PM
shooer's Avatar
shooer
shooer is offline
So I found these HP charts and 169 sure doesn't sound like much for my 400. In 84-86 there was a 351 HO with 210 HP and a 4 bbl. What did they do to bump up that 351?
Engines:
<table class="wikitable" border="1"><tbody><tr> <th>Engine</th> <th>Years</th> <th>Power (SAE net)</th> </tr> <tr> <td>240 CID Straight-6</td> <td>1973-77</td> <td>
</td> </tr> <tr> <td>300 CID I6</td> <td>1973-77</td> <td>
</td> </tr> <tr> <td>302 CID Windsor V8</td> <td>1969-72</td> <td>130 hp (97 kW)</td> </tr> <tr> <td>352 CID FE V8</td> <td>1973-77</td> <td>
</td> </tr> <tr> <td>360 CID FE V8</td> <td>1973-76</td> <td>145 hp (108 kW)</td> </tr> <tr> <td>390 CID FE V8</td> <td>1973-77</td> <td>195 hp (145 kW)</td> </tr> <tr> <td>460 CID 385 V8</td> <td>1973-79</td> <td>200-220 hp (150-162 kW)</td> </tr> <tr> <td>351 CID 351M V8</td> <td>1977-79</td> <td>163 hp (122 kW)</td> </tr> <tr> <td>400 CID 400M V8</td> <td>1977-79</td> <td>169 hp (126 kW)</td></tr></tbody></table>
Engines:
<table class="wikitable" border="1"> <tbody><tr> <th>Engine</th> <th>Years</th> <th>Power</th> <th>Torque</th> <th>Notes</th> </tr> <tr> <td>232 CID Essex V6</td> <td>1982-83</td> <td>
</td> <td>
</td> </tr> <tr> <td>255 CID Windsor V8</td> <td>1980-81</td> <td>
</td> <td>
</td> </tr> <tr> <td>300 CID Straight-6</td> <td>1980</td> <td>117 hp (87 kW)</td> <td>255 lb·ft (346 N·m)</td> <td>1bbl</td> </tr> <tr> <td>300 CID† Straight-6</td> <td>1980</td> <td>120 hp (89 kW)</td> <td>260 lb·ft (353 N·m)</td> <td>1bbl</td> </tr> <tr> <td>300 CID Straight-6</td> <td>1981-86</td> <td>115 hp (86 kW)</td> <td>255 lb·ft (346 N·m)</td> <td>1bbl</td> </tr> <tr> <td>302 CID Windsor V8</td> <td>1980-85</td> <td>130 hp (97 kW)</td> <td>243 lb·ft (329 N·m)</td> <td>2bbl</td> </tr> <tr> <td>302 CID Windsor V8</td> <td>1985-86</td> <td>185 hp (138 kW)</td> <td>270 lb·ft (366 N·m)</td> <td>EFI</td> </tr> <tr> <td>351 CID 351M V8</td> <td>1980-82</td> <td>156 hp (116 kW)</td> <td>262 lb·ft (355 N·m)</td> <td>2bbl</td> </tr> <tr> <td>351 CID Windsor V8</td> <td>1980-82</td> <td>156 hp (116 kW)</td> <td>262 lb·ft (355 N·m)</td> <td>2bbl</td> </tr> <tr> <td>351 CID Windsor V8</td> <td>1983-85</td> <td>150 hp (110 kW)</td> <td>280 lb·ft (380 N·m)</td> <td>2bbl</td> </tr> <tr> <td>351 CID HO Windsor V8</td> <td>1984-86</td> <td>210 hp (160 kW)</td> <td>305 lb·ft (414 N·m)</td> <td>4bbl</td> </tr> <tr> <td>400 CID 400 V8</td> <td>1980-82</td> <td>158 hp (118 kW)</td> <td>276 lb·ft (374 N·m)</td> <td>2bbl</td> </tr> <tr> <td>420 CID Navistar diesel V8†</td> <td>1983-86</td> <td>170 hp (130 kW)</td> <td>315 lb·ft (427 N·m)</td> <td>IDI</td> </tr> <tr> <td>460 CID† 385 V8</td> <td>1983-86</td> <td>214 hp (160 kW)</td> <td>362 lb·ft (491 N·m)</td> <td>4bbl</td> </tr> </tbody></table> † Only available F-250 HD and F-350
Old 01-16-2011, 06:03 PM
79 Custom's Avatar
79 Custom
79 Custom is offline
Thank you
I was wondering what the difference in a 79 351m and 87 302 efi are. If the 87 302 is the same as the 86 I'm in good shape. This 302 is in an 87 e 150 club wagon with a beefed cam in it.
Old 01-16-2011, 06:11 PM
1967 Turbo 6.9's Avatar
1967 Turbo 6.9
1967 Turbo 6.9 is offline
The 70s were a sad time.
Bought a new 79 brand X 3/4ton 350 4speed 4X2. Even with the grannie low 1st in the 4speed when I dropped a rear tire in a hole out in the middle of a dry field I was stuck couldn't spin a tire.
6inarowmakeitgo
32
05-05-2022 09:56 PM
kymadan
04-20-2007 08:47 AM
CR250Bronco
1978 - 1996 Big Bronco
10-03-2005 07:44 PM
Quick Reply: Horsepower ratings, Interesting
