Kickdown cable. - Ford Truck Enthusiasts Forums
Kickdown cable.
Old 08-03-2009, 04:27 PM
shawn_N's Avatar
shawn_N shawn_N is offline
shawn_N is new and has a neutral reputation at this point.
Kickdown cable.
I have a 1988 F250/351w. I was replacing the TBS when either i broke the Transmission kick down cable or it was already broke. This is not a DD, it is and was purchased to mud bog. no road driving or anything along that nature. Just mud. My question is this. Can i get by without having to buy another cable? just run without it connected?
Old 08-03-2009, 08:39 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
If it's an AOD tranny the answer is no the tranny will be burnt before you get out of the driveway.
Old 08-04-2009, 04:11 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
My guess is that it is a C6 so you can do without the cable.
Old 08-04-2009, 12:47 PM
shawn_N's Avatar
ok, so where in the hell can you pick one up at? this thing seems pretty rare from the re-actions i am getting from the parts stores.
Old 08-04-2009, 02:16 PM
First thing you need to do is identify what transmission you have. Get under and count the number of bolts around the transmission oil pan. If there are 17 bolts you have a C6 and if 14 you have an AOD. Like Conanski says if it is an AOD you will fry it without the cable.
Old 08-04-2009, 02:52 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold
Shawn, I'd put the cable back on and if your not sure how to properly set if,I'd have the tranny shop do it. Like others have said if you leave it off or don't adjust the new one properly you'll burn out the clutches in it.
Old 08-04-2009, 04:23 PM
1966Tbird's Avatar
1966Tbird 1966Tbird is offline
1966Tbird is starting off with a positive reputation.
if you have a c6 and just want to race it i don't know about mud racing but for drag racing we just sip tie the kickdown linkage on the tranny so the tranny thinks the kickdown is engaged all the time
Old 08-04-2009, 05:36 PM
shawn_N's Avatar
I raided the junk yard about an hour ago and picked up a couple of them for 5 bucks. hopefully this time though i dont get the chiggers.
FYI though, called all the auto parts stores=NO.
Ford deadliership?=discontinued.
Junkyard=FTW.
EDIT. 17 bolt tranny pan. my superior mathmatical skills never let me down ( i cant count )
Old 08-04-2009, 05:43 PM
shawn_N's Avatar
P.s. thanks to those who said i would have fried my tranny. if not i would have just left it off. good thing i really do listen though, so big thanks to you all. i really do appreciate it.
Old 08-04-2009, 06:10 PM
shawn_N's Avatar
so due to me thinking i know what i have ( i was missing a couple of bolts in the pan ) in conclusion i have a 17 bolt tranny pan, and a "S" shaped pan, i have a C-6.
park brake cable blue924.9 1987 - 1996 F150 & Larger F-Series Trucks 3 09-02-2015 07:27 PM
Accerelator Cable Replacement jtcoker 1961 - 1966 F-100 & Larger F-Series Trucks 3 11-15-2014 02:59 PM
Broken Speedo Cable Clip FordIowan 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-11-2012 08:46 PM
Starter cable gauge? Rose Clifford 1999 - 2003 7.3L Power Stroke Diesel 13 12-05-2011 04:20 PM
Starter cable corroded off. Stangfire 1997 - 2003 F150 1 05-27-2011 07:31 AM
Tags
1990, 85, 99, adjusting, adjustment, adjustment1990, c6, cable, f150, ford, kick, kickdown, location, ranger, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
