Best tire for drag racing?
Wondering what the best type of tire is for our trucks for racing at the drag strip...
I figure since mine is 2wd I'll need a nice wide tread pattern to hook up well... probably a 305/85-16
Would a all-terrain be best? I want something affordable but will hook up. (Wife would kill me if I bought drag radials or slicks, too much $$$)
Ya know the best tire question is loaded because the best for one isnt the best for another...
I would think for saving money sake... A bald set of sand tires???
You need the most rubber touching the surface. Sidewall give.
You might even find an old pair of big slicks at a swap meet, that equal a 31 or 33 inch tire.
Get an old pair of alluminum rims to for less rotating mass. a couple or 4 bead lock bolts on either side.
Had a friend used to go to tire stores and buy old tires, experiment with them, 5 or 10 bucks, they have to pay to get rid of them,,,, might be worth the time,,, the Nitto's I had on my Ex hooked up pretty good, course it weighs 8000# but,,, they didn't break loose as much as the goodyear MTrs,,
Semper Fi Brownie, how is ol nort kakalakie, I used to live out on Pony Farm rd,,,, eeoooonnsss ago!
If I could I'd buy a pair of 33x12.5 slicks for the back... but right now I just want something cheap I can run till I can get the rest of my mods done.
Still need a locker and chip!
I'm gonna check out the used tire places and maybe find something good.
Oh yeah, difinately putting some ladder bars on! Have you seen the ones, forget who makes them, but they are incorporated into the rear leaf springs?
Kinda interesting idea. I'll try to find a link later.
Found this one that ties into the springs:
http://www.ultimateautoaccessories.c...source=Froogle
I know they wouldn't be as good as ladder bars but would they be good enough for occasional racing?
Also why are they listed as 4wd only when the axle and springs are the same as 2wd?
If you've got enough weight in the bed, the tires won't matter!
Seriously, a straight tread would do best. The widest tire you can put on the rim with the least amount of air. Just make sure that you don't spin the rim inside the tire. There is a tire sealer that you can use that would help that out if it's an issue. I would find a couple of used, cheap/free tires first. Does your truck have a limited-slip rearend?
As long as I'm just running them at the track unloaded I could use passenger car tires right? Even though the load rating is low? I'd probably be running my old 235/85-16's on the front so they can hold the weight of the engine.
