F-250 6.0 Flashing Tow/Haul Mode
We have a work truck that driving down the freeway it shifted down a gear for no reason and then the tow/haul mode light started flashing. This lasted about 5 minutes and then it shifted back into overdrive, the light quit flashing, but stayed on. When we pushed the tow/haul mode button it shut off and it seems to be working as normal now.
We werent towing anything at the time that this happened, any ideas?
Truch has about 90,000 miles, all services are up to date, we run full synthetic in the tranny.
Leon
Leon
Last edited by Leonandlisa; 08-03-2009 at 12:39 PM. Reason: Added more information.
Just noticed this - there is only one fluid approved for the Torqshift - Motorcraft SP. What fluid are you running?
Just like he said, you'll find it in the top of the rear differential. It is the Vehical Speed Sensor. I can't tell you how to test it, but you could check it for a loose or corroded connector.
Street Rail
1999 to 2016 Super Duty
09-29-2015 08:57 PM
66 BADBOY
Modular V10 (6.8l)
13
01-12-2012 06:33 PM
