need an engine tag decoded ! - Ford Truck Enthusiasts Forums
Old 08-03-2009, 11:31 AM
williamwilliam's Avatar
williamwilliam williamwilliam is offline
williamwilliam is starting off with a positive reputation.
Getting ready to do a little restore on my 68 Ranger and I have been looking for an engine tag decoder and cant find one. Can anyone decode the following info for me?
360 68 2
8 E K 300 K
Thanks in advance!
Old 08-03-2009, 12:43 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
looks like a plain jane FE 360 with 2 barrel carb.
Good truck motor, not a gas sipper, easy to upgrade to a 390 with a crank rod upgrade.
Better not to convert to 4 barrel without a rebuild and making it a 390. IMHO
John
Old 08-03-2009, 01:31 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
360 68 2
8 E K 300 K
Thanks in advance!
Engine ID tag found on the coil bracket or intake manifold.
360 = 360 2V / 68 = 1968 / 2 = Change Level *
8 = 1968 / E K = FoMoCo use / 300 is the code for a 360 2V - VIN engine code Y / K = FoMoCo use.
* Change Level. In 1968, there were two different length pushrods used. This was a "running change" so there is no serial number break.
Pushrods: Level 1 (L/1) = 9.62" O/A length // Level 2 ( L/2) = 9.59" O/A Length.
Old 08-03-2009, 01:34 PM
already upgraded with a cam, 390 crank with cobra jet rods, edelbrock intake with a 600 box, electric choke. Runs awesome!
Old 08-03-2009, 05:54 PM
jowilker's Avatar
Then it doesn't make any difference what's on the tag, because that engine is no more.
John
Old 08-03-2009, 07:27 PM
thats true, but its still nice to have the tag on it for show.
Old 07-04-2012, 02:24 AM
A_Silva736 A_Silva736 is offline
A_Silva736 is starting off with a positive reputation.
well i got a tag off a 300 I bought awhile back and I figured I'd ask what it all means if it's not too much trouble.
300 68 11 (FoMoCo)
7-H N150-J
Gratis
DECODING VIN # TAG ON MY 67 M250 HANDSOME 1967 - 1972 F-100 & Larger F-Series Trucks 20 10-27-2015 09:30 PM
AOD Identification Help mikidymac Clutch, Transmission, Differential, Axle & Transfer Case 8 09-25-2014 07:21 AM
68 F 600 vin decode pinn600 Large Truck 2 05-11-2011 09:56 AM
Help decoding 429 engine ID tag dani9678 1967 - 1972 F-100 & Larger F-Series Trucks 4 03-15-2010 04:32 PM
Can someone decode my axle? desperado_18_2000 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 01-29-2003 02:45 PM
Tags
1963, 2008, code, decode, decoder, decoding, engine, f150, find, ford, id, location, plate, tag, tags
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
