460 wiring, module, etc. - Ford Truck Enthusiasts Forums
Old 08-03-2009, 03:11 AM
Chad711's Avatar
Chad711 Chad711 is offline
Chad711 is starting off with a positive reputation.
Here is the predicament Im in. I have a 460 out of my old truck, mid 80's. The style that had an ignition module on the fender. Anyways, the engine bay was torn apart for another rig a few years back, so it was all cut out.
I want to wire this 460 into a new project. Does HEI or anyone make an aftermarket module, or do I have to stick with that stock one. I went through a few of those wheeling back in the day.
Also, does anyone have a link or can inform me on how to wire that module.The distributer has 3 wires, again I need basically everything. Diagram or info would be great...
Thanks, Chad.
Old 08-04-2009, 01:15 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Your original dist will run a MSD 6A aftermarket ignition. Here's a diagram if you want to run the original Ford duraspark module.
Old 08-04-2009, 07:32 AM
Chad711's Avatar
Thanks Dave! by the way, this 460 is going in a 69 Firebird.. Actually its already in it
Old 08-06-2009, 04:04 PM
PerfDistIgnition PerfDistIgnition is online now
FTE Sponsor
PerfDistIgnition is starting off with a positive reputation.
Thanks, Chad.
Yes, we make performance modules(and coils) for the Duraspark system-see:
http://www.performancedistributors.c...dduraspark.htm
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
http://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
Ignition Lesson of the Month: Hystereses, the difference between the timing as the rpm and vacuum increases to the timing as rpm and vacuum decrease, needs to be kept to a minimum. A precise advance curve accomplishes this.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old 08-07-2009, 05:39 PM
Chad711's Avatar
Thanks, but I had this distributer recurved awhile back, ran great...
Old 08-01-2011, 07:34 AM
86blackthunder 86blackthunder is offline
86blackthunder is starting off with a positive reputation.
hello i also have a 460 project same year I'm in the process of swapping cabs 84 250 the cab is shot so i bought an 84 150 cab great 100 bucks what do i need from the old cab to make it run I'm making a pull truck the wiring is pretty rough I've had it running for a bit i was hoping a couple of toggle switches and a push button any advice would be great it dose have to be perfect just taking it to local fairs and building as time goes thanks alot
Old 08-01-2011, 09:39 AM
Franklin2's Avatar
You need a momentary switch running to the "s" terminal of the solenoid to make it crank, and you need a switch to the coil + and to the ignition module to make the spark. You may need a resistor to the coil depending on what ignition you are running.
What's the difference in ignition modules? Harkijr 1973 - 1979 F-100 & Larger F-Series Trucks 23 01-26-2016 10:25 PM
Need help decoding a Canadian VIN please chad77 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 08-25-2015 02:46 PM
99 exp electrical? fe8u Expedition & Navigator 3 01-12-2014 01:05 PM
Patch RKE module into Antenna? GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 7 11-18-2013 07:40 AM
Duraspark I ignition module montana_highboy 1973 - 1979 F-100 & Larger F-Series Trucks 40 05-07-2010 08:48 PM
Tags
1978, 1989, 460, codes, diagram, distributor, distrubuter, engine, ford, ignition, module, number, rpm, truck, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
