wire diagram - Ford Truck Enthusiasts Forums
wire diagram
Old 08-03-2009, 01:36 AM
390428cjt 390428cjt is offline
390428cjt is starting off with a positive reputation.
wire diagram
Does anybody have the wire info for the plug harness to the instrument cluster on a 96 w/tach and without tach cluster? There seems to be a couple of wires on the plug that are in a different position for a cluster without a tach,,, mine came without a tach and want to switch to the cluster with the tach. Any help would be great or even a link that has it in laymens terms.
Old 08-03-2009, 01:46 AM
Sportruk's Avatar
Sportruk Sportruk is offline
Sportruk is starting off with a positive reputation.
This is the only pinout diagram for the cluster plugs. It appears the only difference is the location of the Fuel Level Input wire.
Old 08-03-2009, 01:59 AM
Sportruk's Avatar
Looking at the rest of the cluster diagrams, the Fuel Level Input wire splices to both plugs already. The pinout diagram just indicates which one is used with or without the tach. You will find the Yellow/White wire on both plugs. I don't see any difference between the wiring of the plugs. It's the same with or without the tach.
Are you sure the tach cluster you have, is from a '96?
Old 08-03-2009, 08:03 PM
its from a 95 f150 when I hook it all up the batt light stays lit even tho it is charging had the system checked it all check good.
Old 08-03-2009, 11:35 PM
Sportruk's Avatar
Here's the '95 pinout. The difference is the '96 has a Brake Fluid Level/RABS input (pin 11) and no theft light (pin 5) while the '95 has no Level/RABS input (pin 11) and has a theft light (pin 5). I do not know if that would be causing the issue with the battery light.
I would try pulling pin 11 out of the plug and taping it up. Looking at the instrument cluster diagrams, it shouldn't affect the RABS. It's only to indicate that you have low brake fluid levels. You still have an active Antilock Brake light.
Pin 5 isn't an issue because you don't have a wire in that pin location and don't need it for the '96.
Old 08-05-2009, 11:28 AM
This is helpful. Now there are two plugs plus the speedo plug which isnt a problem ,,,the plug showing in pics is for the left side correct? what is the other one do exactly?
Tim
Old 08-05-2009, 01:10 PM
Sportruk's Avatar
Each picture has both plugs, a gray plug and a black plug. Not sure which is the left plug or the right plug. The first pic if for the '96 cluster and the second is the '95 cluster.
Old 08-05-2009, 01:17 PM
jmkelly jmkelly is offline
jmkelly is starting off with a positive reputation.
Where are you guys finding the pin-out diagrams? That resource would come in really handy for a project I have planned...
Old 08-05-2009, 01:39 PM
ok I figured it out after removing the cluster as to both plugs on diagram now after hooking it all up its the check engine lite that is on constant when running not the brake lite and the airbag indicator lite doesnt lite up now like it did on original cluster. I looked at the circuit board on the original cluster it has the pt# >>>>>>
F5TF-10C956-A the one I want to use has # F2TF-10C956-B my truck is a 1996 and was produce towards the end of the model year for 96 so I assume the cluster is a 95 and the one I want to use is a 92 however it came from a 95 Lariat. Do you have a pin out for 92 and up im wondering if there was a major difference in the years on wiring setup for the cluster and if I cant move the pins around in the plug to work with the cluster then would I need a cluster from a 96 yr specific?!!
Tim
Old 08-05-2009, 02:15 PM
Ok blk one is on the right side looking at it as installed in dash with cluster in.
Old 08-05-2009, 03:07 PM
Sportruk's Avatar
Here is the '92. The new cluster you have will be missing the Airbag Light if it is from a '92. As I recall, if the Airbag light is blown, it will produce a beeping from under the dash, so if it is missing and you hear something, that's what it is.
Old 08-05-2009, 03:37 PM
Ok this doesnt have the airbag light instead it has an lite that says AMP where the airbag lite would be on my setup and the other lite next to it says SFT ? where the would normally be the theft lite (which isnt used in my truck anyways) so its looking like I need a cluster or printed circuit board from a actual 95 or 96 truck I want the airbag lite to work as it was intended as well as the others on my truck. You know of any available I can purchase with the tach setup or just the circuit panel (plastic circuit panel/foil) somewhere I check several yards around me with no luck I payed $40 for the one I have now which works great but isnt for my truck year I dont see changing around the pin location in my plugs to be an advantage as it is missing the airbag circuit on the printed panel. Im very greatiful for your time on the pin diagrams you sent me, and was a big help in solving this issue. BTY what year was the airbag started its use in the ford truck?
Tim
PS looked at your chrome yellow truck very nice.
did you see my 72 ?
Old 08-05-2009, 03:56 PM
This cluster does have the RABS and Anti Theft lite on the printed circuit with the bulbs.Also I know the 95 & 96/97 were the same as far as the body style but I think the 96 was unique from the 95 in some ways it was the last year for this body style in the F150 but continued in 97 for the F250/350 in 98 the body style was changed for the f250/350 to catch up with f150. My original cluster has the theft setup but I have never seen the light lite up ever and the bulb is good so Im not sure how that is suppose to work anyways.
tim
Old 08-05-2009, 04:28 PM
Hey hate to be a PITA do you have the 93 &94 pin out as well, also do you have the printed circuits diagrams for the clusters in relation to the pin diagrams?
Tim
Old 12-06-2009, 06:56 AM
jcbx jcbx is offline
jcbx is starting off with a positive reputation.
Hi
do you have the page 60-1 to 60-5 you could project as I need to figure out how to wire my "check trans" and "Airbag" instead of the "low range" and "4x4"
as I have an instrument like this going into my 92 E-line
Thanks in advance
Sincerly
JCBX
Quote:
Tachometer wiring question JoeNoble 1987 - 1996 F150 & Larger F-Series Trucks 4 08-15-2015 09:18 PM
87-91 Diesel Tach Into Non-Diesel Cluster RacinNdrummin Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 09-20-2014 11:26 AM
Cluster wiring- add a tach? Handegard 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 02-22-2014 11:27 AM
Guage Cluster Swapable? stydel311 1987 - 1996 F150 & Larger F-Series Trucks 23 11-20-2013 08:17 AM
Factory tach rowdyredneck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-03-2013 10:45 AM
Tags
1987, 1996, 58, 72, 73, 96, ac, charging, diagram, f150, f250, ford, light, tach, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
