wire diagram - Page 2 - Ford Truck Enthusiasts Forums
wire diagram
Old 05-04-2010, 11:11 PM
arownious arownious is offline
arownious is starting off with a positive reputation.
Got Ranger and SportTrac diagrams
Quote:
Originally Posted by Sportruk View Post
Here's the '95 pinout. The difference is the '96 has a Brake Fluid Level/RABS input (pin 11) and no theft light (pin 5) while the '95 has no Level/RABS input (pin 11) and has a theft light (pin 5). I do not know if that would be causing the issue with the battery light.
I would try pulling pin 11 out of the plug and taping it up. Looking at the instrument cluster diagrams, it shouldn't affect the RABS. It's only to indicate that you have low brake fluid levels. You still have an active Antilock Brake light.
Pin 5 isn't an issue because you don't have a wire in that pin location and don't need it for the '96.
Where did you happen to get this diagram and would you happen to have the equivalent for a 95 Ford Ranger 4cyl without tach and a 2001 Sport Trac with tach and bigger block engine?
I switched out/upgraded my cluster for one with a tach but I need to figure out how to get the new tach grounded as the 95 4cyl doesn't have the proper grounding cable.
Thanks!
Old 04-25-2014, 02:31 PM
jakegaisser's Avatar
jakegaisser jakegaisser is offline
jakegaisser is starting off with a positive reputation.
Where did you guys get these excellent wire diagrams? I am putting a 1994 dash into a 1991 truck, so that the newer 1995 E4OD transmission will shift and the speedometer will work.
We picked up the dash at pick a part yesterday, I am wondering if anyone has a diagram for the HUGE plug (30ish wires) that goes through the firewall, my 1991 truck has a round plug, and the 1994 dash uses a rectangle plug, I am planning to rewire the 1994 dash to my 1991 round firewall plug.
here is a thread about the project: http://www.ford-trucks.com/forums/13...eedometer.html
I dont even necessarily need a diagram that shows the routing of wires etc, just a picture of the plugs at the firewall with a pinout list with colors and what they go to would work, would need to get one for the 89-91 and one for the 92-96 so that I can wire the 94 dash up to the round 91 firewall plug.
Old 06-17-2014, 09:11 PM
OConnorRacing's Avatar
OConnorRacing OConnorRacing is offline
OConnorRacing is starting off with a positive reputation.
anyone no where I can find the pinout diagram for a 1986 F 350?
John
Tachometer wiring question JoeNoble 1987 - 1996 F150 & Larger F-Series Trucks 4 08-15-2015 10:18 PM
87-91 Diesel Tach Into Non-Diesel Cluster RacinNdrummin Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 09-20-2014 12:26 PM
Cluster wiring- add a tach? Handegard 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 02-22-2014 12:27 PM
Guage Cluster Swapable? stydel311 1987 - 1996 F150 & Larger F-Series Trucks 23 11-20-2013 09:17 AM
Factory tach rowdyredneck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-03-2013 11:45 AM
Tags
1987, 1996, 58, 72, 73, 96, ac, charging, diagram, f150, f250, ford, light, tach, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
