wiper arms
If you lift the wiper arm up at its pivot you can use a pair of needle nose pliers to grab that "clip" and it slides up. If I remember the setup correctly, the clip sort of slides using those screws. They act as the guide. But yeah.... If you do it youll know what im talking about.
Lift the wiper, grab the clip with pliers, slide it up.
When its up you can let go of the wiper arm as it will just rest on the open clip. The wiper arms are on a splined cylinder so they pull up. They may be a little stuck. Careful so you dont hurt it.
