Synthetic Oil - Ford Truck Enthusiasts Forums
Synthetic Oil
Old 07-01-2001, 07:50 PM
trhea6922 trhea6922 is offline
trhea6922 is starting off with a positive reputation.
Synthetic Oil
I recently purchased a new ford truck (diesel). Is synthetic oil all that they say it is? Also, if I choose to start using synthetic oil, which is the better brand.
Also, one last question.....if I choose to use synthetic how many miles needs to be on the truck before I start with synthetics?
Thanks for all your help.
Tom
Old 07-01-2001, 11:46 PM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Synthetic Oil
Be absolutely sure that the synthetic you choose has all of the ratings called out in your owners manual. I understand that Powerstrokes are very sensitive to oil foaming and gasoline engine oils do not contain enough anti-foam additive. Most diesel owners stick with Shell Rotella, Chevron Delo, or similar oils.
Old 07-05-2001, 02:52 AM
dcovell dcovell is offline
dcovell is starting off with a positive reputation.
Synthetic Oil
My dad sells motor oil for a living (Kendall mainly) and I have used a Ford F-150 Inline 6 300. I have used Kendall in my truck now for 5 years and after 112,000 miles it still runs like the day I bought it. I would have to say the Kendall is the best oil. Now I have been told that synthetic is basically a waste of money on gas engines unless you race around, basically run the engine hot or at high RPMs, the synthetic does cost quite a bit more, another benifit is that it stays more of a liquid in really cold weather and not quite as thin in really hot weather.
As far as a diesel oil goes, I'm not really sure but this link might be able to help you out...
http://www.kendallmotoroil.com/market/dieselenf.htm
Again it depends on what type of driving you do, if you offroad a lot it may be worth it to get the synthetic but for everyday driving I think your wasting your money.
Also when oils say that they go beyond 3000 miles, be careful, especially if your driving offroad with a lot of dust. The oil detergents and dispersants can only do so much and then the oil can't hold any more stuff in it.
Hope this helps, whatever you do don't run Penzoil, it's the worst oil there is!!!
One more thing, I hang out at the race track once in a while, if you get a chance ask some of the drivers if they have ever heard of Kendall, they will most likley say yes, and thats all I use. No kidding, even Nascar cars will use it, the same formula as you can get in the store.
Old 07-06-2001, 01:09 PM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
Synthetic Oil
Check out the July 2001 issue of Highways Magazine(Good Sams Club) page 28. They address the topic of oil for Ford Diesels. I have never owned a diesel so I was surprised at the answer they gave.
In general the usual answer, "Use the API service rating and SAE certification called out in the manual" is correct. My interpretation is that if the syntehtic API and SAE ratings meet your manual specifications, then you are OK. Often one brand of oil or another will meet specs for current passenger cars but not diesels, I guess this is one time where it is very important to make sure you follow spec.
What surprised me was that the engine oil is also actually used in the injectors of the diesel engine. I thought this was a lot of hooey until I read more and now it makes sense. From what I can interpret, the injectors use pressurized engine oil to activate themselves. I would guess the typical electrically activated solenoid as used by gas engines is not capable of handling the pressures involved in the direct injection used by the PowerStrokes. I don't know since I never used a diesel but makes sense to me now. The process of pressurizing the injectors can cause foaming so if the oil does not meet the specifications you can get too much foaming which could lead to component failure. The Magazine seemed to favor Rotella(Chevron?) oil for the PSD engine.
Good Luck,
Jim Henderson
Old 07-09-2001, 01:55 AM
DJMaryland DJMaryland is offline
DJMaryland is starting off with a positive reputation.
Synthetic Oil
Use the synthetic as soon as possible. I like Mobil1 Delvac for my F550. You might also want to start oil analysis with a service like Blackstone Labs, etc. Also, Amsoil and Redline oils have excellent reputations, and Amsoil does carry extensive sideline products such as filters, bypass systems. The synthetic with the oil analysis will keep the PSD going several hundred thousand miles before teardown/rebuild. The oil analysis will save you money in the long run because you will be able to extend the change interval.
Good luck !
Old 07-13-2001, 02:47 AM
MEPHISTO_XES MEPHISTO_XES is offline
MEPHISTO_XES is starting off with a positive reputation.
Synthetic Oil
[font size="1" color="#FF0000"]LAST EDITED ON 13-Jul-01 AT 03:40 AM (EST)[/font][p]Used Castrol full synthetic 5W50 in my Nissan. Got 426,600 brutalized miles on it. No knocks,pings,or,dings. Runs like it was new. Some people don't like synthetics.
I don't know if this is true,but I was told diesel lube oil
contains parafin as an additive to protect against main/rod bearing wear.(?)
Never use checkvalve type filters on Fords. The bottom end will
clatter and will not stop untill you switch back to a motorcraft filter.Experienced it with 5 Fords. One with only 067,000miles.
Quakerstate is the worst. Pennzoil is second.
Garett
Old 01-10-2002, 08:26 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Synthetic Oil
Old 03-18-2002, 09:36 AM
Stab Stab is offline
Stab is starting off with a positive reputation.
Synthetic Oil
Once again the shadetree experts chime in about Pennzoil/Quaker State. It seems some people refuse to listen/learn.
Everyone I know with a PSD uses Rotella. Synthetics are a waste of money in 99% of engines. The greatest benefit of synthetics is piece of mind.
Old 03-31-2002, 11:59 PM
fourphils fourphils is offline
fourphils is starting off with a positive reputation.
Post Synthetic Oil
Hey Stab I find it hard to believe that synthetics
are a waste of money when their is not a petroleum
based oil on the market that can stand up against
them.
Old 04-01-2002, 05:44 PM
RJKobbeman RJKobbeman is offline
RJKobbeman is starting off with a positive reputation.
Synthetic Oil
>them.
First, I see you still can't read: "NO DEALERS"
Second, Stab stated that synthetics are a waste in 99% of engines. He did not say dino was better. He just said syntehtics are a waste in most of our applications.
Let me try to explain this to you... It means that building an oil that exceeds an engine spec to the nth degree is a waste. Spending buku bucks on an oil that will protect your engine in ways it will never need protecting is a waste.
I like good synthetics like the next guy, but I still subscribe to the "change your oil regularly -- with ANY good oil, dino or otherwise" theory.
So what if x-brand dino does not stand up to Amsoil or whatever brand synthetic? It still protects your engine the way it is needed.
Of course, you are an Amsoil dealer. I wouldn't expect you to understand. Of course, you are also in the 95 percentile... and I don't expect you to understand what that means either. Ask Stab, he'll tell you.
Old 04-01-2002, 05:55 PM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputation
Synthetic Oil
RJK:
Mr. fourphils has been warned by our host.
Old 04-02-2002, 09:53 AM
Synthetic Oil
horsepuller,
Thanks. I am not trying to be the forum police. I just understand why no dealers are welcome here. There agendas cloud good honest discussions.
If there was a way for them to join the discussion as a 'person' and not a 'dealer', I guess it wouldn't be any big deal. But Ken -- and all of the other moderators -- has obviously learned that that is impossible.
Old 04-04-2002, 11:34 PM
Synthetic Oil
Thanks for the back up RJ. 5% er's have to watch each others backs.
I'm glad a Amsoil dealer showed up. I want to buy some for 0.88 per quart. That is what I pay for Formula Shell and they perform the same in my engines. Send me out a case for that price and I'll switch.
Old 04-05-2002, 12:29 PM
Synthetic Oil
Old 04-05-2002, 02:43 PM
dinosaurfan dinosaurfan is offline
dinosaurfan is gaining momentum as a positive member of FTE.
Synthetic Oil
Yeah, the synthetic oils are better than mineral oils. Are they better enough to justify the exspense ? Well, that seems to be debateable. A lot of that would depend on where you live. I live in Michigan, and it is still winter here. (April 5 today) there are spots in this state that still have 4 ft of snow on the ground and it is plenty cold. Being somewhat of a stick-in-the-mud old guy, I just can't get myself to use the newer thin engine oils some guys like. AND I'm still running FE power. So I've always used 20-50 oil. But the gooey stuff doesn't move very fast in the cold, and I can hear the bearings tapping as the engine starts in the cold. Not good. But Mobil1 15-50 allows the engine to crank fast and start easily even in sub zero weather. If you live someplace warm, it may not be important. DF
How to tell if old oil was synthetic or not Snowseeker 1999 - 2003 7.3L Power Stroke Diesel 8 07-16-2011 07:27 PM
Using Synthetic Oil In High Mileage Motors Skullonarm Excursion - King of SUVs 16 12-09-2008 01:40 AM
Synthetic Oil Unimog005 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 22 08-05-2007 10:04 AM
Synthetic oil use ? rrzielin Oil & Lubrication 18 07-31-2005 12:12 AM
rear axle lubricant tlkennedy2 Clutch, Transmission, Differential, Axle & Transfer Case 1 03-22-2003 12:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
