Testing the P I P sensor - Ford Truck Enthusiasts Forums
Old 08-02-2009, 05:46 PM
Rackpatrol's Avatar
Rackpatrol Rackpatrol is offline
Rackpatrol is starting off with a positive reputation.
How do you test the pip sensor on a 1995 5.8 bronco. I think I have it narrowed down to the PIP . No Spark Good Crank
Old 08-02-2009, 11:02 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Old 08-02-2009, 11:47 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
I just solved this problem on my Bronco 1990 5.0L AOD automatic last summer, or maybe it was fall. Anyway I ended up rebuilding the distributor with all new parts. Stator, PIP, Cap, Rotor. Doing that fixed the no run problem but it was still running roughly, and now the fuel pressure drops when it gets hot. So it's an ongoing challenge. Yea!
check engine light code P0155 nitrored 1997 - 2003 F150 7 10-03-2016 06:03 PM
HEI dizzy upgrade jordandkaspar 1987 - 1996 F150 & Larger F-Series Trucks 2 09-09-2016 10:38 PM
pip sensor fault code stevenjf88 1987 - 1996 F150 & Larger F-Series Trucks 9 06-16-2015 09:03 PM
1987 Ranger PIP sensor code Alto Ranger & B-Series 17 05-11-2014 03:19 PM
PIP Sensor? Scott54321 1987 - 1996 F150 & Larger F-Series Trucks 21 10-03-2013 06:28 PM
Tags
1990, 1995, 302, 58, 90, 96, bronco, f150, ford, location, pip, sensor, spark, stator, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
