Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 08-04-2009, 12:51 PM
redwing22 redwing22 is offline
redwing22 is starting off with a positive reputation.
Quote:
Originally Posted by dkf View Post
Do you guys cast the heads there also? Did you guys cast the blocks for the modulars have been made at the windsor plant? I know Ford has done some juggling lately.
I'm shure 5w-40 will flow fine thru a new engine at room temp. Let the motor sit in subzero weather overnight and start it in the morning with 5w-40. See how its does after 150k+ miles on the thick stuff and the motor builds up some deposits. The head passages are also very important also as the cams ride right on the aluminum.
Yes we cast all of the gray iron blocks.No we do not cast heads here any more. Unfortunatly they are aluminum and cast in Mexico by a co named Nemak.
Yes the oil will flow at room temp and also at -30 as it is a 5 weight oil it only picks up the traits of a 40 weight as it gets hotter.
Remember we make a 750 to a 1000 engines a shift, oil is brought in in tankers (Castrol by the way) as assembly plants call for engines some go over seas some are domestic some are for 150s others are for 250s and up, some go to Austraila for the Falcon ,some go to Africa for stationary punps and generators. Everything gets cold tested with 5 w 20 as it exits the assembly plant.
I am not saying your wrong, use what you feel is right for you. Oil today is light years ahead of the stuff of only 10 years ago.
  #32 (permalink)
Old 08-04-2009, 01:03 PM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
No worries. I tried looking for oil weight specs for different countries for the modulars without much luck. The modular market is obviously the strongest in north america.
Do you do all the machining work there also? Sucks the heads are mexican made. I guess they go where electric and labor is cheap because aluminum takes a lot of juice to get molten.
  #33 (permalink)
Old 08-04-2009, 01:34 PM
we only do rough finish here at Cleveland on the cast iron blocks. we do all the mach. and assembly on the 2.4, 2.5, 3.0, 3.5, 3.5 and 3.7 eco boost.
  #34 (permalink)
Old 08-04-2009, 02:25 PM
Monster-4's Avatar
Monster-4 Monster-4 is online now
Who? Me?
2000 Ford F-250
Monster-4 has a good reputation on FTE. Monster-4 has a good reputation on FTE.
Is this the plant by CLE?
__________________
Mike
2000 F-250, SC, SB, 4X4, Lariat, 6.8 V10, Auto, 3.73, Ford Racing headers, SCT X3 87 Performance tune by 5 Star Tuning
  #35 (permalink)
Old 08-04-2009, 03:15 PM
Yes.it is right off 71
  #36 (permalink)
Old 08-04-2009, 03:23 PM
Monster-4's Avatar
Who? Me?
2000 Ford F-250
Cool thanks. Just wondered since I went by your plant several thousand times in the pasted 11 years on my way to/from the airport.
__________________
Mike
  #37 (permalink)
Old 08-04-2009, 04:22 PM
Mustang6147's Avatar
Mustang6147 Mustang6147 is offline
Mustang6147 is gaining momentum as a positive member of FTE.
Quote:
Very intresting posts. I have alot of family that retires or still works at the walton hills plant... I deliver alot to your plant... The days of Roadway express ect..
I have a few questions ,maybe you can answer. In on of your posts you mention trucks bringing in oil (castrol) that being said, WHy not motorcraft??? the test results are very different between Castrol and Motorcraft, so they arent the same. WHy??? That popped into my mind whuile reading, maybe you dont know the answere maybe you do.
__________________
06 SuperDuty 4x4 extcb 5.4, TorqShift, 4:10.
90 Mustang 9's, 750 HP Windsor. Ultratech Chassis
http://www.youtube.com/watch?v=pibt-TVgAx4
41 Plymouth 49 dodge flathead6 elec ign.
Sig Sauer P229 Two tone.
  #38 (permalink)
Old 08-04-2009, 04:36 PM
You know come to think of it I don't know. Never really thought about it. I know our plants have a contract with Castrol for all oil, Hyd. mach.grease and lubeoil and I do the oil analysis thru Castrol. Good question!
  #39 (permalink)
Old 08-04-2009, 04:54 PM
It popped into my mind... I had to ask. If you get around to it or a chance to find out, will you either post it here, or IM it to me??
At you conveience of course
__________________
  #40 (permalink)
Old 08-04-2009, 05:05 PM
I will try to find an answer and let you know. That was a great question!
  #41 (permalink)
Old 08-04-2009, 07:02 PM
dkf's Avatar
dkf dkf is offline
Are you guys running straight dino in the engines for break in? That may explain why you use castrol instead of MC blend oil because last I believe MC blend is made by conoco phillips in the US.
  #42 (permalink)
Old 08-04-2009, 09:55 PM
popatop500's Avatar
popatop500 popatop500 is offline
popatop500 is starting off with a positive reputation.
Talking Oil type in the engine ?
What type of oil is in the engine when I get it new ?
  #43 (permalink)
Old 08-04-2009, 10:32 PM
Read post 31, I asked him why not MC he is going to look into it.
Very intesting HU??
__________________
  #44 (permalink)
Old 08-04-2009, 11:25 PM
Pinky Demon Pinky Demon is online now
Pinky Demon is starting off with a positive reputation.
Hey CLE guys! Brookpark plant unite!
I'm personally running Mobil 1 5w-20. I ran Motorcraft and I noticed that you lose a little of that stuff too. No biggie, all engines consume a bit.
__________________
2002 F-250 - V10, Crew Cab, Short Bed, Lariat 4x4 aka My Lovely Big Girl.
Click HERE for my full review w/ pictures of the Banks Powerpack Exhaust System.
  #45 (permalink)
Old 08-05-2009, 12:16 AM
I am curious here also about engine oil weight, or viscosity... I was impressed with Castrol Edge test results, but they dont have 5w20 yet.
Will 5w 30 be the same??
__________________
Tags
1997 , 46l , 54l , changing , dino , ford , oil , passages , rx , syn , synthetic , useing , v10 , van , winter , worth , yamaha
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
