Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 08-02-2009, 01:11 AM
jeff9942's Avatar
jeff9942 jeff9942 is offline
Garage is empty, add now
jeff9942 is starting off with a positive reputation.
Key Ignition Replacement
1994 F150 XLT 351 cid
What is the trick to changing the ignition switch on the steering column?
  #2 (permalink)
Old 08-02-2009, 04:09 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Do you mean the ign switch lock barrel with the key or do you mean the electrical ign/start switch?
  #3 (permalink)
Old 08-02-2009, 09:49 AM
jeff9942's Avatar
switch lock barrel
  #4 (permalink)
Old 08-02-2009, 10:13 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
turn key to run, stick 1/8" drill in hole below the cylinder, remove cylinder, put in new cylinder.
__________________
"To believe is to know you believe, and to know you believe is not to believe." ~ Jean-Paul Sartre
  #5 (permalink)
Old 08-02-2009, 10:18 AM
jeff9942's Avatar
well that sounds like an easy trick
Thanks quick
  #6 (permalink)
Old 08-02-2009, 10:23 AM
quicklook2's Avatar
if you want one key then go to a locksmith and they can key the new cylinder to match your door key.
should be around 40 bucks or so.
the hole is on the bottom of the column and accessed through the plastic below the key.
__________________
Tags
1987, 1994, 94, company, f150, ford, ignition, key, keys, lost, motor, replace, replacement, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
