99 F-250 5.4l V8 How many quarts?? - Ford Truck Enthusiasts Forums
Old 04-09-2002, 12:04 PM
Stab Stab is offline
Stab is starting off with a positive reputation.
Old 04-10-2002, 02:29 PM
BuckNrut's Avatar
BuckNrut BuckNrut is offline
BuckNrut is starting off with a positive reputation.
I just bought a 99 Ford F-250 5.4l Triton V-8 and cant find the owners manual. Can anyone tell me how many quarts of oil it holds? Thanks
John:-X11
Old 04-30-2002, 10:23 AM
Sportdeck262 Sportdeck262 is offline
Sportdeck262 is starting off with a positive reputation.
The Triton V8s & V10 all say 6 qts, but with the filter it takes 6.5 qts to get up to the full mark.
Old 05-01-2002, 10:36 AM
I've never had a Ford with a "full mark" on the dipstick. Just a crosshatch with a min. and max. range.
Put in 6qts and if the level is between the hashmarks leave it alone. The most common problem when a novice changes fluids in a car is overfilling. Overfilling is as bad as underfilling the oil.
Later
Stab
Old 05-01-2002, 01:24 PM
LK LK is offline
LK is starting off with a positive reputation.
[updated:LAST EDITED ON 01-May-02 AT 02:34 PM (EST)]My 4.2 is 6 quarts with a filter change, which puts it halfway between the add and full marks on the stick - and I'm pretty sure my manual says that the 4.6 and 5.4 are also 6 quarts, at least in the F150 for the '01 model year. However, the pan used on the F250 might be slightly larger - using 6 1/2 quarts doesn't seem unreasonable. Personally, I would just start with putting in 6 quarts and see where that is on the stick (once the engine has been started and the oil circulated, and then allowed to run back into the pan for a few minutes). I think the sticks are pretty close in the newer engines, as opposed to some of the old 302s where they were only accurate within a quart or two.
BTW, most of the Fords I've owned did have "add" and "full" marked on the stick - as do both the '89 and the '01 I own now.
LK
Old 05-01-2002, 02:09 PM
[updated:LAST EDITED ON 01-May-02 AT 03:11 PM (EST)]test
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
Salvage yards Oklahoma Chapter 14 04-11-2003 10:33 PM
Superchargers walterdanek Ford Inline Six, 200, 250, 4.9L / 300 16 02-16-2001 07:56 PM
Tags
2002, 46, 54, 54l, 68l, 99, f250, ford, oil, overfilling, quarts, triton, v, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
