Back-Up camera installed
Old 08-01-2009, 10:51 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
A couple of months ago, one of the Excursion forum members passed on to us fellow Excursion members a great deal his local Sam's Club was having on back-up camera systems.
I ended up getting one for $25 bucks, plus $15 for flat-rate shipping via USPS.
A few weeks back, I finally got around to installing the system in my truck. I installed and mounted the viewscreen for my back-up camera on the trans tunnel floorboard, but didn't have enough time to finish the install before the Riffraff Tech Day. So, a couple weeks ago, while up in Oregon for tech day, Pete helped me finish wiring up and installing the rest of the system.
I figured I'd share the install with the rest of you guys.
Here is the monitor installed on the trans tunnel floorboard. The power wire for the monitor had an adapter on the end for plugging into a power source receptacle. I didn't like that so I cut the adapter off and hard wired it into the power source wires behind the dash.
In the above picture, next to the brake controller, you can see a plastic knockout where Ford places the power pedal switch.
I decided I didn't want to wire the camera to the reverse lights, only powering it whenever I put the gearshift lever in reverse, so I installed a rocker switch there, powering the camera whenever I wanted, not just when it's in reverse.
Here's a picture with the dash popped off to access the wires to the pedal switch harness:
After getting power to the rocker switch, I ran the antenna wire down the frame of the truck and drilled a small hole under the drivers side door sill, placing a grommet in the hole, then placing the antenna in the void and hooking the wires into the antenna module.
Here is everything all finished.
Stewart
Old 08-01-2009, 10:59 PM
agg_bagg's Avatar
agg_bagg
agg_bagg is offline
looks good man i would like to have something like this.... i use alot of trailers at work and i don't know how many times i get out get in get out of my truck trying to get it right.....
Old 08-01-2009, 11:28 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
$25??? Stewart you are under arrest for robbery or theft. Is that a typo? Nice setup. Where did you mount the camera? I know, out back, but I'd like to see a pic of that. Great setup buddy. Nice work.
Old 08-01-2009, 11:54 PM
87 F-150 I6's Avatar
87 F-150 I6
87 F-150 I6 is offline
wow, what a steal of a deal. Good write up and great job on the install! A backup camara is a great idea and one I would also like to have.
Old 08-02-2009, 12:05 AM
Stewart_H's Avatar
Stewart_H
Mike, I didn't post the picture because it was taken at night and I didn't like how it turned out. I've been meaning to take a picture during the day, but here it is.
I drilled a small hole in the plate, placed a grommet in the hole to protect the wire, and ran the wire through the plate so it didn't show anywhere.
VA Sheriff, a member in the Excursion forum, discovered his local Sam's Club was having a blow out sale on these systems and he posted in the forum, asking if any of us wanted any.
A ton of us replied, and when I finally saw the thread, the price at his Sam's Club had dropped from the $41 they were on sale for, down to $25 bucks. VA Sheriff didn't make a dime doing this for the member in the Ex forum, he just passed the savings on to us.
Stewart
duck fan
112
08-21-2023 09:52 AM
Stewart_H
20
07-09-2012 05:33 AM
Stewart_H
05-17-2012 03:03 PM
Stewart_H
07-14-2009 06:00 PM
Quick Reply: Back-Up camera installed
