Spark Plug Drama Update_nickel anti-seize on ground shield made HUGE difference!!
Good News! The second spark plug change was MUCH easier then the first.
I replaced the original spark plugs at 40K. I didn't break a plug during that first change, but the plugs were really screeching and moaning on the way out. Along with being pretty hard to turn out. I followed the TSBs removal instructions.
I was really hoping the second set would come out easier, since I put the nickel anti-seize on the ground electrode shield of the replacement set, as recommended by the TSB.
I followed the TSB when removing the second set except, I used Aero-Kroil instead of the carborator cleaner.
I loosened the plugs 1/8th to 1/4th a turn, then let the plugs soak for 1 hour before I started wrenching them out. I'm very happy to report that the second set came out with no drama at all. I didn't get any squeeking and moaning as the plugs were being removed. They came out fine.
I could have waited longer to replace these plugs but I wanted to replace at the same interval as the originals (40K miles) in order to be able to really see if the anti-seize made a difference.
In conclusion, the anti-seize will make your future plug changes much easier.
Here are some pictures of the second set of plugs that were just removed. There is some carbon build up, especially around the upper ground electrode shield.
Oh,ok.I have the 4.2 so I did not know that is where carbon builds up on those type plugs.BTW,that is alot of carbon!
crawlfish
12-02-2004 04:11 PM
