ESOF to manual conversion - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-31-2009, 10:54 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
I just got done swapping my ESOF system over to old fashioned manual. I got fed up with it when the shift motor went out for a second time (along with a wiring problem at one point) When I was in the market for a truck I was pretty dead set on getting one with manual shift, but I found the exact truck I wanted everything else was right except for this so I bought it.
I got a shifter boot and lever/**** assembly from a salvage yard, and bought the bellcrank (pivot point) that mounts on the trans from ford (no salvage yard would sell me one off a trans) I made my own shift rod out of .500'' square tubing and 3/8'' heim joints. I modded the shift motor with an external lever and its all working great. All 4x4 lights work as they should etc.
Just thought I would post my results as Ive seen several people ask about doing this.
Old 11-15-2010, 04:08 PM
f250-ksa f250-ksa is offline
f250-ksa is starting off with a positive reputation.
now u r my friend
i've looking for this thread for a long time
any way i have the same problem that you have
i had the transmission out for some services, the car stayed out of work for more than 1 month
when i started the car, here the story begins
the transfer case didnt work, so i checked it on the dtc and it showed that the transfer case has gone!
i bough it recently (sr 900) = $ 240
the best part of the story was when i installed it, (it didnt work)! i mean the motor
now i am looking for a conversion !
i figured that the connector doesnt stay connected, it goes back !!!
any way you dont want to hear my life story.
and please if you can put some pictures so we can do the same thing
this is the connector, it seems like it is already connected but it isnt
this is the new motor
ESOF Woes - This one is complicated sevensecondsuv Excursion - King of SUVs 6 01-02-2017 03:23 PM
ESOF and solid axles Cai Garage 1997 - 2003 F150 6 05-24-2016 05:06 PM
2003 F250 ESOF Clarification Tkrobinson 1999 to 2016 Super Duty 0 07-06-2015 10:34 AM
2003 F350 locking hubs vacuum lines ken.stevenson 1999 to 2016 Super Duty 2 02-11-2013 12:14 PM
4x4 and ESOF problems BWPowersmoker02 1999 to 2016 Super Duty 5 01-02-2010 02:33 PM
Tags
1999, case, conversion, converson, converting, duty, esof, f150, f250, f350, ford, manual, shift, super, superduty, transfer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
