Help, needle roller bearing collapsed?
I have an 02 F250 4wd, and the needle roller bearing on the inside of the front hub is making a hell of a noise. I am 400km from home, and I am unable to get a bearing for 3 days. There is no play in the wheel, just a lot of noise. Will it get me home?
Pete
Pete
Thanks for your replies guys
I swallowed my pride and paid $780 for a National hub from korea that was the only one available in Sydney, Australia's biggest city, I could not get the bearing alone for 3 days. In two days time I will have a Timken Hub that I ordered last week landed from Rock Auto for $450, at least I will have a spare for next time. How many miles do you guys get out of a hub?
Pete
Pete
on
I think a lot has to do whether you drive through a lot of water or not. Mine has 145k miles on both (I am assuming they were never changed). I also believe they will last as long as you own the truck if you grease the needle and hidden roller bearings about every 50k miles. I packed mine full of grease through the ABS sensor hole a while back and they are doing great with all the grease staying in. If you don't have the sensor hole you can easily drill a hole and then plug it or add a zerk fitting. I have a post with pics in here on it. Both my hubs took a full mini-tube of grease. If you look at Guzzles needle greasing web page you will see that he greased the main hub bearing even though he didn't mention it.
