oil pressure and rocker arms
I am assuming Losse = Loose if that is correct, then No...
Why?
Fluctuateing oil pressure readings are usually caused by something restricting... An oil filter that is cheap, (FRAM) bad sending unit, if electronic... Or weak oil pump. Once the engine rpms is above 1500 it should be pretty steady, although still climb
Why?
FossenRacing
06-04-2012 07:24 AM
C-Leigh Racing
28
01-10-2009 10:07 AM
rowdy78
01-13-2008 12:13 AM
Zaratul
09-14-2003 01:57 AM
1965f-100swb
07-22-2003 05:33 PM
