hit a bump and truck shut off?????? - Ford Truck Enthusiasts Forums
Old 07-31-2009, 05:13 PM
sand1's Avatar
sand1 sand1 is offline
sand1 is starting off with a positive reputation.
hit a bump truck shut off for 3 sec. came back on then died turned key to start and tach needle was moving up and down did this 3 times then finally started??? wtf is going on truck is a 99
Old 07-31-2009, 05:35 PM
spdmpo's Avatar
spdmpo spdmpo is offline
spdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to behold
Might I be the first one to suggest checking out the UVCH?
Old 07-31-2009, 05:46 PM
sand1's Avatar
not the uvch jus did the quarter trick on both sides it only does this when the truck is going up in elavation (same mountain 3 times now)
Old 07-31-2009, 05:51 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
Does it shut off instantly or like it's running out of fuel (slowly peters out)?
IDPisan's Avatar
IDPisan IDPisan is offline
IDPisan is gaining momentum as a positive member of FTE.IDPisan is gaining momentum as a positive member of FTE.
How big a bump? These trucks have a fuel shut off if you get involved in a wreck or sometimes if ya hit a big bump it will set it off. The re-set is on the passenger side kick panel, take it off and re set.
Old 07-31-2009, 05:56 PM
fifthwheel01 fifthwheel01 is offline
fifthwheel01 is starting off with a positive reputation.
mine did that and the trip o meter would reset.
Just throwing this out there...... Loose battery cable????
Old 07-31-2009, 05:58 PM
Izzy351's Avatar
I'd check the PCM connector & tuner/chip (if applicable) as well...
Old 07-31-2009, 07:27 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Quote:
Quote:
Either of those, or start checking the wiring harnesses / connections. If a connector is loose it can do that. Also the main engine wiring harness (over the drivers side valve cover), the harness over the top of the front drivers shock, the harness inside the steering column are possibilities as well.
Unless you know of a different mountain to take.
Old 07-31-2009, 07:42 PM
Hiflyer746 Hiflyer746 is offline
Hiflyer746 is gaining momentum as a positive member of FTE.Hiflyer746 is gaining momentum as a positive member of FTE.
Underneath the airbox bolted to the inner fender liner is a terminal stud for a power cable going from the batt to the Fuse Relay box in the cab. These studs corrode heavily and give you a high resistance connection. I bet a million bucks thats what your problem is. Pull the airbox completely out and you'll see the heavy gauge wire that runs through a 1" square plastic cap. Pull the cap off and see how nasty that connection is! Keep us posted.
Timmy
Old 07-31-2009, 07:54 PM
F350-6's Avatar
Quote:
Timmy
Dang Timmy. A million bucks is something I might have to take you up on. Do you really think there's that big of a corrosion issue in Arizona?
I'm down in Texas where we have humidity and I don't have any corrosion issues.
Old 07-31-2009, 10:13 PM
I didn't notice the arizona. . . but that problem is definitely a bad connection. And the way he describes the gauges ticking tells me its that cable. I've seen that many times and to be honest it didn't look like the stud had direct contact with lots of water or road salt. . . but I'd definitely check that cable out from the batt to the fuse relay board.
Timmy
Old 07-31-2009, 10:37 PM
papadelogan's Avatar
papadelogan papadelogan is offline
Snowboard season cometh..
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
Chris - oddly enough in CO (where it's super dry) my battery connections would get cruddy super fast, but not in MD (where it's nasty humid). Strange, but true. Nothing rusts in AZ or CO really, but man will electrical stuff get "furry"
Driving along, hit a bump...truck dies.... FordBlueHeart 6.0L Power Stroke Diesel 63 10-09-2016 04:06 PM
Hit a bump and died turns over white smokes but no start travismoore 1994.5 - 1997 7.3L Power Stroke Diesel 15 02-11-2016 06:16 PM
Any Ideas? 08 F350 shuts off when breaking hard or hitting a bump dcl25c 6.4L Power Stroke Diesel 6 07-07-2015 09:38 PM
Truck keeps shutting off when I hit a bump. dustinsheeler717 6.0L Power Stroke Diesel 5 06-15-2015 09:30 PM
hit bump,won't start sg1099 1987 - 1996 F150 & Larger F-Series Trucks 8 08-09-2011 08:00 PM
Tags
07, 2001, 2004, 60, 73, bump, bumps, diesel, f150, f250, f350, ford, hit, hitting, shuts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
